Question about Kenmore Washing Machines
Cold water just trickles in but the other temps come in good why
  • 15,935 Answers
Turn off the cold water valve - and remove the hose at the machine. Check/clean the inlet screen. It regularly fills with sediment and calcium deposits.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
I replaced a moen 1222 valve stem becasue i had just a trickle of water. I go the new stem in ok, but still no water. I have the hot water heater diconnected on the water inlet, but the out let is still...
With posi-temp cartridges, if one supply of water, hot or cold, is interrupted, the cartridge automatically restricts the flow of the other water source. This is to prevent you from getting scalded if the pressure on the cold side drops because of a toilet being flushed or any other uses of cold water. The cartridge will only allow cold water to flow through if there is hot water to balance it out. If you restore hot water to the faucet, it will operate properly.
Aug 04, 2017 | Moen 2919 Chateau Two Handle Tub and...
Cold water runs slow
Turn the cold water off and remove the hose at the machine. You will find a screen located there and you will need to clean it out.
Apr 27, 2012 | Washing Machines
The cold water trickles. There is a "good" flow of water (hot&cold) to the machine yet, the cold water trickles out on any cold setting. The hot water has great flow. What could be the answer?
Sounds to me like your inlet valve is gunked up. You will need to replace your inlet valve. I would also check your hoses first to make sure the cold water hose does not have a screen on it that is full of calcium deposits. Hope this helps _MJ_
Aug 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold water only trickles in
Assuming you have good water pressure to the inlet valve, you probably have a blocked or faulty inlet valve...Not a big job....Good luck...Nomess
May 16, 2010 | Washing Machines
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water good for a few minutes then slows to a trickle. Shut off for a few hours and cold water good again for a few minutes. Inlets are clear. Is this normal behaviour for a dying valve?
Yes, it will fail soon. it is beat to go ahead a order a new inlet valve assembly asap. the pressure sensors that are housed in the valve assembly are failing.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Whirlpool LSR8233EQ0 Hot water (only) trickles
you need to replace the hot cold inlet water valve on the back of washer,the solinard for the hot water is not opening all the way,this is a common problem on all washer,if you go to sears .com click on parts put in your model number you can get the part and it shows you where it goes,hope this helped you-mike
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer approximately 2 1/2 year old
The screen at the cold water inlet is clogged. Cut off the cold water line and unscrew the line to the washer at the washer. Use a flathead screwdriver and pry out the metal screen that is visible Wash it out in a sink and re-install it. Re-attach the water line,turn it on and your'e good to go. If not you will need a new water inlet valve. These are the only things that can cause your problem unless there is a problem with your cold water supply pressure. Good Luck!!!!!
barneyluc
Oct 03, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
