Question about Troy Bilt Tb70ss Gas Trimmer
I just put new fule lines on how do they go back and the pump ball
My 1994 BMW 740i will not run but motor is cranking turning over and trying to start to run like lack of fule.
Try spraying carb. cleaner in throttle body while turning the key. If this works, most likely have a bad fuel pump. Good Luck
May 02, 2017 | Cars & Trucks
In stall mechical fule pump 305v8 how to steps instrections.
here is a paicture of the pump, it is held into the engine with 2 bolts, once the lines are removed and the 2 bolts a push rod that operates the pump will fall out, goob grease all over the push rod and put it back in the hole, clearn the gasket surface with a razor blade or gasket knife apply sealer to the new gasket (use "HighTack") then install the pump and reconnect the lines, do not overtighten the fuel line clamp or overtighten the outlet line, use a specail wrench called a line wrench, failure to use this special tool will ruin the fuel line nut.
Aug 21, 2010 | 1985 Chevrolet Sportvan G20
2001 Windstar: how to install a fule pump...
drop the fuel tank (2 bolts) remove sending unit. install new unit. put tank back in. easy job with an enpty tank :)
May 16, 2010 | 2001 Ford Windstar
Fuel pump problems. I have replaced my fuel pump on a 1995 chev 2500. Truck will not start unless i prime it with gas. Fuel is not getting to the motor. What am i missing
you may have an air leak in the fule line from the fule tank this is letting fule run back to the tank when you stop the engine running over night check all the fule pipes are air tight and do not have crossed or striped threds on them
Apr 12, 2010 | 1995 Chevrolet Silverado 2500
My car was out of fule now I have put 10l of fule on him but I cant get any pressuer in the fule line
When you ran out of fuel, you must have BUrned up the pump.. Gasoline is cool,,, and it helps keep the pump COOL. Therefore, by running out of fuel,,,
Mar 01, 2010 | 1997 Jeep Grand Cherokee
FUEL INJECTORS DONT WORK,FUEL WONT TURN OFF, LEAKIN SOUND COMEN F
First thing.. take the fuel lines loose and turn the key to the on posistion and see if the fuel comes out of the line. It sounds to me like you may have fuel pump issues...
Dec 17, 2009 | 1991 Ford Mustang
My 2003 TDI vw is losing the fuel out of the fuel line and I do not know why can not see any leaks. The car just will not start after it sits for a couple of days. I can bleed the car threw the injectors...
its not loosing the fule its running back into the tank, you have an air leak in the suckshion side of the fule line, a pin hole some were or a leaking joint it could even be in the fule pump itself or the fule filter "o" ring is leaking air but thats were the problem is try fitting a none return velve to the fule pipe upto the pump
Nov 15, 2009 | 2003 Volkswagen Jetta TDI
The engine will not run unless you pour gas in the carb. It ran before i charged the fuel line which was rotted off. It is 2 cycle blower vacuum and i do not have the model nomber handy
its that new fule line you put in,,,its not letting any fule down to the carb you have proved there is nothing wrong with the engine, by tipping fule into the carb,,,,
have another go at fitting the new fule line,,, rember to put on the fule filter on the end that gos inside the fule tank if its not on it the pipe will not lay in the fule tank right and wont pick up any fule out the tank,,,
i bet thats were you went wrong?
Nov 10, 2009 | Craftsman 4 Cycle Blower/Vac
I have a roybi 31cc weed eater and the fule line has become brittle and has broken apart. I need to know the layout of the new plastic fule line. I purchased a new fule line at Lowe's. I do not know wich...
STEP (1) The fuel supply line has the filter attached inside the fuel tank. The other end of that line goes on the carburetor's SUPPLY NIPPLE.
STEP (2) Determine the primer bulb's flow direction by pumping it under water. The unused nipple on the carb (IF STEP 1 WAS DONE CORRECTLY THERE IS ONE UNUSED NIPPLE STILL AVAILABLE ON THE CARB) will have a section of fuel line attached to it and running to the SUCTION NIPPLE (or pull-side, as some techs call it) of the primer bulb.
STEP(3) The final piece of fuel line goes from the OUTPUT NIPPLE (or push-side, as some techs call it) of the primer bulb and is routed back into the fuel tank as a return.
If plumbed properly, the primer should PULL fuel thru the carb and NOT pump any fuel into the engine. Excess fuel should be pumped back into the tank on each and every press of the primer.
Hope this helps!
Sep 28, 2009 | Garden
Stalls when giving it gas
these were hard to fix when they were new in 1990, question:::: does it run and rev-up hi normally in neutral/park??? with a timing light does the distributor show full advance???you claim "CUTS-OUT", like back-firing ??you may need to test the COIL, TPS (throttle position sensor) and LOOM to isolate the cause,.. try those and let me know the outcome....GL
Jul 06, 2009 | 1990 Ford Ranger SuperCab
Troy Bilt Tb70ss Gas Trimmer Logo
168 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
