Question about Canon LBP 1120 Laser Printer
Installation Printer was not used for a period. Now unable to install on a new computer
  • likin01_park Jun 25, 2008
    printer not use for sometimes.
    driver disk missing.
    tried several times download through internet but failed.
    seems there is no connection between printer and note book.
    all wired connection done.
    kindly assist a.s.a.p.
  • 62 Answers
If you still have the installation disk, you can.
what is the operating systems of the new computer?
if it vista you proberly need the updated drivers.
You can download it from the support section from Canon's website
Posted on May 14, 2008
I am unable to uninstall my lexmark printer driver from my laptop... i was trying to install the new driver and it refused to over ride the previous installed driver and then i did a system restore and now...
Please try this. Run the install disk/web installer -> select Support -> select Uninstall. If Uninstall initializes, reboot your computer after the process finishes. Then reinstall using the new driver.
If the "Uninstall" option is not available, it would be best to contact Lexmark technical support for assistance.
NOTE: MAKE SURE TO USE THE PRINTER DRIVER COMPATIBLE WITH YOUR COMPUTER'S OPERATING SYSTEM.
Nov 11, 2010 | Lexmark X2550 All-In-One Printer
I disconnected the printer from the tower for computer service with a local vendor(blue screen). Repair completed. When I reconnected the printer, I discovered that I was unable to print documents from the...
Open Control Panel, Printers and faxes. Check if there is icon for your printer. If not, you have to install the driver using CD that comes with the printer.
Blue screen often means very badly broken windows installation and your vendor probably reinstalled it as new installation. Therefore your printer may not be installed.
Jun 15, 2010 | Dell 924 All-in-One InkJet Printer
Trying to install printer to new computer unable to locate printer model
please use the disk of the printer. maybe the new computer won't recognize the printer driver.
Mar 05, 2010 | Canon MX300 Office All-In-One Printer
Epson r320 printer w/ no advance settings when linked w/ new IMAC
I had the same problem when installing my Epson R300 onto my new iMac (Snow Leopard). The first install used the newest online driver from Epson. The printer symptoms were exactly like yours. Then I installed the Apple driver updates. It was seamless and now the printer settings can be accessed. Perhaps if you uninstalled (read about that on the Epson site first) and then downloaded the new factory driver, followed by the Apple update which will further update files, you might have some luck. Just a guess on my part. Best wishes.
Mar 04, 2010 | Epson Stylus Photo R300 InkJet Printer
Ink system has failed. Unable to print. Error: Oxcc 18a 0201
See if you can install your printer on another computer and then try printing with it again.
Run a test print first to be sure and check your print out. If this fails,
Run a print head cleaning using the printer utility setting. If it does not work,
Get another Black ink and try it out again. Cheers!
Apr 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Unable to download sony handycam movie to computer
Installed macromedia flash player. After a short period of time, left plugged in and running, wizard detection of new program kicked in and went through series of setups. Screen stays small but does allow to download to computer.
Jan 28, 2009 | Sony Handycam DCR-HC36 Mini DV Digital...
Unable to install Lexmark 8300 printer
You can find the set-up manual of your printer here.....www.lexmark.com/publications/eng/8300/index.html
I need you to make sure that the driver you are using to install the LEXMARK 8300 is compatible with VISTA.
you can download them at, www.driversplanet.com/device.php?id=107349
Before installing the new driver you have to uninstall the old one. If the system is not permitting to uninstall the driver, then try installing the new driver by the following steps:
ensure your printer is connected to your computer and the power is on
 1.) click start / right click computer and select properties
2.) click device manager
3.) Click View then show hidden devices
4.) right click on the printer and click uninstall
5.) Unplug your printer usb from your computer
6.) RESTART
7.) INSTALL THE PRINTER WITH THE VISTA DRIVERS YOU DOWNLOADED..
 REMEMBER NOT TO PLUG IN YOUR PRINTER UNTIL THE SETUP SOFTWARE TELLS YOU TO DO SO.
Hope my info will solve your problem, Thanx for using fixya, Good luck.
Sep 29, 2008 | Microsoft Windows Vista Ultimate Edition
No installation software
My lexmark z1300 worked great on my Hp computer with windows xp, but that computer no longer works. Now I am back on my Gateway with windows 98 and I am unable to install a driver for my printer, I need to print out a very important document from the irs and I am unable to do so. Please Help!!!
Jan 30, 2008 | Lexmark Z1300 InkJet Photo Printer
Lexmark x3580 printer
This doesn't sound like the exact text of an error message... if you can get me an exact quote, that would be helpful. But, the time out period expired sounds like it was failing to communicate with the printer. The first thing to do would be check the cable between the printer and the computer - make sure it's firmly in place on each end. Then, make sure the printer is coming on, and with it on try to install again.
If that doesn't help, please post the exact text of the error message and I will look into it further.
-Dyllan
Dec 18, 2007 | Office Equipment & Supplies
Canon LBP 1120 Laser Printer Logo
57 people viewed this question
old marine
old marine
