Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Installed 1/2 HP - H4000-07/M overhead garage door opener. When I press the button on the remote control, I'm getting no response. When I pluged the operator in to the 110 outlet, the lights came on the operator but I get no response from the rmote controls or the wall mounted control. I disconnected the safe-T-Beam & still no response. I disconnected both the wall button and the T-Beam, still no response.
4 Suggested Answers
Door Tech
  • 98 Answers
SOURCE: Gargage door was acidently closed
If you have a keyless entry it will still open the door with the vacation lock on. I assume you tryed this or don't have a keyless entry. There is no other way to activate the operator. Sorry but you will have to make a way in.
Posted on Jan 03, 2009
  • 3197 Answers
SOURCE: IChmberlain Garage door does not pen or close
The light flashing 5 times is the code for "RPM sensor or motor overload" and the 10 clicks sounds like the relay for the main light bulb that flashes when the door sensors are blocked or misaligned.
If you want an owners manual and have Adobe Reader you can go here and get one.
http://www.chamgerlain-diy.com/pdfdocs/A2490M.PDF
Posted on Oct 15, 2009
  • 547 Answers
SOURCE: I have an older model, say 15 years, Chamberlain
The lighted switch is powered by the opener itself. This has the handy feature that, if the light is on, you know you're connected to the opener.
You're seeing the opposite -- no light, which means no connection, which means the button doesn't activate the opener.
There should only be two wires going from the opener to the wall switch, and they're typically 22 or 26 GA solid wires, like telephone wiring.
Given the age of your system, odds are good that one of the wires has broken off at one of the ends -- either inside the wall switch or at the back of the opener. If that's the case, just strip off a little more insulation and screw the wire down again.
If you don't see anything broken, then try this:
When you have the wall switch open and you're looking at the wires, try shorting them with a screwdriver (or just touch the wires together for a moment)
They're low voltage (24V) so you won't get a shock from them.
Shorting them should activate the opener, just as if you'd pressed the button.
If that works, but the light is still not coming on, then you've just got a broken switch. Most hardware stores or home-improvement stores will sell you a replacement for a very low price. Truth be told, you can also just put a doorbell switch on there -- they're based on the same voltage/light/switch system.
Posted on Jan 27, 2010
Rest the opener?
You will find a button (smart/learn) just to the left of where all those white wires go on the Unit installed inside the garage to open the door. Press and hold it for 6 seconds. This will erase the memory in the opener and your remote should no longer work. Now press and hold the large button on your remote and then press and immediately release the smart/learn button on the garage unit. Your unit is now reprogrammed.
Apr 25, 2016 | Craftsman 1/2 HP CHain Drive Garage Door...
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
MODEL 139.53975SRT1 1/2 Hp opener will not work with any remotes, I tried to reprogram remotes; pressed learn button, the light next to it came on, pressed button on remote, nothing happened. I cleared...
The correct way to program a remote is to hold the button down on the remote and then press and immediately release the learn button. If this doesn't work your logic board is bad.
Nov 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
''Overhead Door'' Garage Door Opener 1/2 HP Model 939 Base Unit Mod
YOU MAY HAVE A BROKEN SPRING.
CHECK FOR A GAP IN THE SPRING ABOVE THE DOOR.
IF YOU DO HAVE A BROKEN SPRING CALL IN A PRO.
THIS IS NOT A DIY PROJECT.
Dec 14, 2009 | General Electric GE 13-438 Overhead Garage...
Having trouble setting garage door opener to my 2004 trailblazer
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
source:chalkstar100 (fixya mate)
Thanks for using Fixya
Have a nice day!
Mar 07, 2009 | 2004 Chevrolet TrailBlazer
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
538 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
