Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mini Mac 35 - oil reserve leaks even when not running. Is there a gasket that I should replace?
5 Suggested Answers
  • 211 Answers
SOURCE: McCulloch mini mac 35. Badly worn chain
Hi
You need a chain with these carracteristics:3/8 ,PM,1.3 and the chain bar has 14" length.Hope this helps.
regards savumihai71
Posted on Dec 09, 2008
  • 4088 Answers
SOURCE: mini mac 35. need to know the fuel/oil mix ratio.
Use 40:1 mix. Be sure to use chain saw engine oil designed for this service, not boat motor oil. Premix the fuel/oil, not in the saw fuel tank itself.
Posted on Jan 28, 2010
dontbother10
  • 2220 Answers
SOURCE: mac 3516 b330 replaced carby diaframme
Are the fuel lines routed like this?
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If yes reply below and we will scratch our heads together. HTH
Lou
Posted on Feb 20, 2010
  • 24 Answers
SOURCE: I have a mini-Mac 35
40:1
40 parts gasoline to 1 part oil
Posted on May 08, 2011
Noticed a bit of smoke coming from under the hood. Opened to look and it seems there's oil next to the valve on my turbo.
Does turbo need oil? Very much so. It has parts spinning at 30,000 rpms or so, and the bearings require oil to live. Clean cool engine thoroughly, and then run engine to find leak.
Jun 04, 2015 | 2008 Mini Cooper S
Change a valve cover gasket on a 1998 voyager plymoth mini van
unbolt the cover and clean all gasket surfaces and replace gasket and cover and bolts
May 16, 2015 | 1998 Plymouth Voyager
What would leak oil onto the starter
the oil leak could be a bad valve cover gasket needing replacement, a head gasket leaking oil, a leaking intake gasket and oil running down along the engine block and dripping. it could be an oil pressure switch that is leaking. it is near the starter while driving or engine running can spray oil onto the starter. unless the oil leak is very bad and has been leaking a long time onto the starter will not cause it to act like a dead battery even then not likely. have a starter draw test down to check condition of the starter.
Sep 23, 2014 | 2003 Ford Taurus
Oi; in coolant reserve
If its engine oil the most common cause is a leaking head or intake gasket.
Jan 23, 2014 | 2002 Saab 9-5
Antifreeze leaking from engine on 2001 ford focus
It sounds like you have a blown head gasket, check your engine oil, take off your oil cap and if it is frothy around the cap and inside the head, you have a blown head gasket.
Jan 12, 2013 | 2001 Ford Focus
How do I replace the fuel filter on a mcculoch mini mac 35
Fuel filter is attached to the feed hose. You'll need to refer to your service manual.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Dec 24, 2012 | McCulloch 1975 Mini Mac 35 Chain Saw Sales...
Manual for McCulloch mini mac 35
Manuals may be downloaded using the provided links:
Contact us
User manuals
McCulloch Service
Aug 22, 2012 | McCulloch 1975 Mini Mac 35 Chain Saw Sales...
Overheating coolant boiling out into reserve tank
you have a blown head gasket.. doesn't have to have coolant in the oil for a blown head gasket... if hoses are rock hard when running then you have exhaust leaking into the coolant via a blown head gasket...
Jul 14, 2012 | 1998 Plymouth Breeze
Looking for a users manual for a late 60's early 70's Mcculloch Mini Mac 35...any ideas?
i run my macs at 30.1 gas to oil and standard bar oil should be adequate, good luck finding a manual...
Jul 04, 2012 | McCulloch Garden
I have a Mini cooper 2002 model, Its not overheating or anything but the water level in the Reserve tank goes very low to nothing in the reserve tank, what would be the cause? I cant see any leak visible...
It could be a slow leak in the radiator or hoses or the head gasket. The antifreeze could be blowing out of the cylinders rather than leaking to the ground.
Dec 25, 2010 | 2006 Mini Cooper
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
94 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
