Question about Vizio L32 32 in. LCD HDTV
My vizio lcd tv gets a shadow on the entire right side it goes away and comes back and if you smack the side it clears.
  • 63 Answers
The cause of this is most likely the lcd controller board cable. it may have a short, open up the tv and wiggle it see if that solves the problem.then just order a new cable it should be under 20 bucks.
Posted on Sep 07, 2010
  • glittergirl1 Sep 09, 2010
    how do you open up the back?
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
Jul 27, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Vizio 46 inch black screen on left side
Sounds like you either have a faulty LCD panel tab, failed LCD driver board, LCD/t-con panel bad connection, or a bad t-con. You will need to get a diagnoses to be sure.
Dec 15, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
A 2" shadow line runing
Hi that can be two things. First your LCD screen might be bad the second thing is your T-con board might be bad. The only way to find out is to actually replace the T-con board. If the line goes away that was your problem if it does not then it's your screen. You can find parts for that TV at www.interliquidparts.com
Jun 08, 2011 | Mitsubishi LT-52246 52 in. LCD TV
Shadow on right side of screen
Can you please give little details of shadow on right side?
Is it Vizio L32 lcd tv or any other model?
These info will help me to diagnose problem.
Thanks.
Nov 28, 2010 | Vizio L32 32 in. LCD HDTV
Vizio 42 lcd gets large dark spot. it will go away if you tap on side of set but comes back sooner ao later
HI...
It's probably a loose flex cable inside. Look on the web and find someone near you
Have a service tech check it inside for you
Apr 22, 2010 | Vizio VU42L 42 in. LCD TV
Red 2 inch vertical line on right side of Vizio TV
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
Aug 30, 2009 | V, Inc. Vizio L6 HDTV-Ready LCD Television
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Vizio L32 32 in. LCD HDTV Logo
439 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
