Question about Frigidaire GLER341A Electric Dryer
WONT HEAT, AND MAKES A SQUEAKING NOISE FROM THE BACK
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
My new nordictrack 1750 is squeaking.
Talk to the manufacturer or take it back. It should not do this if it is brand new.
Jun 10, 2017 | Cars & Trucks
Squeaking delonghi magnifica
Take it apart and clean it properly plug use sileco to lubricate for a longer use water heat coffee all of these make machine to fail
Keep service as importance
Jul 09, 2014 | DeLonghi Magnifica 3300 Espresso Machine
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
Maytag neptune tl...shows op code but the lid is closed and locked and will not unlock.
my he maytag makes a squeaking noise and it wont fill up. could there be a sock stuck in there or something. and the lock wont lock.
Oct 26, 2013 | Maytag Neptune FAV6800AW Top Load Washer
Mazda protege makes a squeaking noise when I start driving?
If your Mazda Tribute's engine has a rumbling noise when you start it, this is most likely from the drive belt. You will need to replace it.
May 30, 2013 | Mazda Protege Cars & Trucks
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
Admiral Washing Machine Makes Squeaking Noise
THE BRAKE IS VERY FAMOUS FOR THAT NOISE NOT INSPECT THE PUMP ,, CAN BE GRINDING ON BOTTOM BASE OF WASHER ,, BEARING POPPED OUT
Nov 22, 2008 | Washing Machines
Dryer makes scrapping and squeaking noise
The front drum support has wore out. Reach your hand in the tub and puch up on it. If it moves up and down a lot the support is wore. Buy a new support and front slides and it will stop squeeling.
Nov 19, 2008 | GE Dryers
Frigidaire GLER341A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
