Question about Garden
I want to install a new water main. It is replacing lead with HDPE but also entering the building at a new location (near the gas meter). How can I make sure I don't accidentally disturb the gas supply while digging the trench. Also, does anyone have a good link to a reference on this DIY project. I am a competent plumber with metal but I've never worked with plastic, outside or near gas :)
  • usedonlytosi Sep 08, 2010
    I am in the UK so digalert no use.
    It's not a tough question I think I already know how to do it, I just a pro giving some tips to make sure I'm not off-key.
    You don't need to see the job at hand, I can describe it to you. I am digging a trench across a garden, can't be paying for the detector to detect pipes/cables but they will be armoured so if I find one I'll just go around it. Then I have to go through a path. The path is probably quite shallow and through the path I enter the building near the gas main, at which point I connect the HDPE to a stop tap.
    Thanks for trying to help tho.
  • usedonlytosi Sep 09, 2010
    This was excellent information. Both my electricity supplier and the national gas grid will provide plans for free of where the lines lay on the property and come and flag them for you if you need it (I think the plans will suffice).
  • 10,865 Answers
Call your utility company and have them come out and mark all of the pipes with small flags. This is a free service. Check your local code or call the gas company as there is most likely an ordinance setting the distance you must dig from the gas line to set a new water line. Also call the water company and let them know what you are doing as they will have to send someone out to inspect the work and hook up the line before you back fill. J.
Posted on Sep 08, 2010
  • 8,197 Answers
Before you dig you need to go to this link. http://www.digalert.org/
Also if you are not sure you are happy with working with the material. I would ask for help. If you ask another plumber they will be more than willing to help you and guide. At least that is the way I am. I relay can not help and no one here can with out seeing the job first hand.
Good Luck
Posted on Sep 07, 2010
Is it normal to smell a faint gas smell near new installation tankless water heater. Installed yesterday.
no
gas smells indicate a deadly situation as an explosion and fire from the build up of gas is a very real possibility
get in a gas fitter with a gas detector to find and fix the leak
Sep 08, 2017 | Water Water Heaters
How do i eliminate moisture from an underground,natural gas galvanized gas line. I have no gas flow to my garage or my 75k garage heater.
Check on the local codes governing gas piping, but it would be my suggestion to consider abandoning the existing line IF you are sure there is a compromise to its integrity allowing water to enter. I would think if water ENTERS...then GAS has to be able to excape. It'd be a lot of condensation that's required to either just block the line or freeze and block the line. If it freezes due to lack of depth, it's going to rupture anyway sooner or later necessitating replacement.
At the above ground location before where it goes subterranean, (after checking the codes), consider installing the appropriate brass fittings to then allow a new underground copper line to be installed by attaching by means of an iron pipe to flare adapter in the appropriate size. Then utilize type L soft roll copper to lay in the new trench to the garage and tie it into the existing line inside the wall. Type L is the thick walled soft tubing and can be used in many locations for gas, whereas Type M soft copper tubing is thin walled tubing for use with water and not gases. Your area may not allow it. That's what building inspectors are for.
Before proceeding, MAKE SURE your line is in fact the problem then double check with a local authority whether or not copper materials are recommended along with brass fittings for the connections. IF the original and suspected problematic gas line is for sure GALVANIZED it is not in any way approved for use with natural gas. It is probably black iron pipe.
Jan 03, 2015 | Heating & Cooling
Leaking hot water heater
If it is older than 15 - 20 years and leaking on the floor under the tank, purchase and install a new appliance, If the T&P valve is leaking, change the valve. If it still leaks, replace the expansion tank which should on the supply water line. Try not to install an expansion tank "on its side". BEFORE YOU DO ANYTHING, make certain your incoming water pressure does not exceed 65 -70 psi. This could be the real problem. If so, install a new water pressure regulator. It is usually located inside the basement wall. In a Garden Home, it may be outside at the curb in the ground by the water meter. It may be in the ground buried near the entry through the foundation. It may be near the water heater.
Feb 02, 2013 | Water Heaters
Hot water heater water, went out main line of house that enters house
You did smart thing turning off water and gas.
Play it safe.
Your water heater will NOT explode.
Conduct routine maintenance so water heater lasts longer. If plumber says you need new heater, then post question on fixya and include information showing on tank label on side of tank.
Also include why plumber says to replace.
Get another plumber.
Call city utility company to determine source of noise.
Dec 01, 2012 | Whirlpool Water Heaters
The pilot is ok.the main burner does not come on
First check and see if the dial on the gas valve is on the ON position. Next turn the thermostat up all the way.if it does not come on then, this sounds crazy, but, tap the gas valve twice lightly with the back end of a screw driver, sometimes a spec of dirt can clog the gas valve and this releases it. if it still doesnt come on, you need a Volt Ohms meter or multi meter, set the meter to millivolts, you want to connect the 2 leads from the meter to the terminals on the gas valve that the 2 wires from the pilot generator, located next to the main burner underneath tank. turn the meter on and the millivolts should read a minimum of 400 milivolts, if lower, replace pilot generator. If still doesnt work, replace gas valve.
Aug 31, 2011 | RTO Water Heaters
We have a brand new Rinnai gas heater, Avenger 25. The first two times we operated it, it was fine, but since then a code 13 comes up after 3-4 minutes and the heater turns off. Rinnai said we could...
These are the possible issues with the unit, based on the code list and description
Check that the gas is turned on at the water heater and gas meter. Check for obstructions in the flue outlet.
Ensure gas line, meter, and/or regulator is sized properly.
Ensure gas type and pressure is correct.
Bleed all air from gas lines.
Ensure proper Rinnai venting material was installed.
Ensure condensation collar was installed properly.
Ensure vent length is within limits.
Verify dip switches are set properly.
Ensure appliance is properly grounded.
Disconnect keypad.
Disconnect EZConnect™ or MSA controls to isolate the problem.
Check power supply for loose connections.
Check power supply for proper voltage and voltage drops.
Ensure flame rod wire is connected.
Check flame rod for carbon build-up.
Disconnect and re-connect all wiring harnesses on unit and PC board.
Check for DC shorts at components.
Check gas solenoid valves for open or short circuits.
Remove burner plate and inspect burner surface for condensation or debris.
Clean inlet water supply filter.
On new installations ensure hot and cold water lines are not reversed.
Check for bleed over. Isolate unit from building by turning off hot water line to building.
Isolate the circulating system if present. Open your pressure relief valve; if unit fires, there is bleed over in your plumbing.
Ensure you have at least the minimum flow rate required to fire unit.
Ensure turbine spins freely.
Measure the resistance of the water flow control sensor.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Heating & Cooling
How much gas (energy) does a rheem HT55 use per hour in average?
I think HT55 is Australian water heater.
You can add a comment and describe the product in detail since I cannot find that number listed on Rheem site.
The problem with water heater ratings is they are meant as industry comparisons for new units that are operating at peak performance. They do not account for factors at your location such as mineral build up, incoming water temperature, faulty parts, un-maintained parts, obstructed venting, etc.
To get accurate number will require work on your part:
1) You can add a gas meter to that one appliance.
2) Or look at gas meter reading at beginning of day. Digital gas meter would be necessary.
Turn off all other gas appliances, or make sure just the pilot light is only thing operating.
For a full day, let the HT55 operate normally.
Read gas meter at end of day.
Analog meter would be hard to read with only one day.
3) Another way is to look at BTU rating of all gas appliances on the same meter.
Figure weighted average of each appliance based on amount of time each appliance operates and amount of gas it consumes when running. Then figure percentage of gas that HT55 consumes. Read the gas meter one day, and then read meter again 30 days later, and take percentage that HT55 consumes.
You can find some helpful information on following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 15, 2011 | Rheem Water Heaters
WHERE IS THE FUSE LOCATED IN THE WHIRLPOOL GAS DRYER
If you remove the back panel. you will see the blower housing on the left side. O n the right side of the blower housing near the bottom you will see the thermal fuse mounted above the operating thermastat. To test you will need a Volt/ Ohm meter. Set meter to RX1, take off a lead, and probe both terminals, Look for zero reading, if its high or infinity you will need to replace.
Apr 10, 2011 | Whirlpool GGW9250PL Gas Dryer
No ice
Three possible causes:
1. The saddle needle valve on the supply line - (your plumbing) - has finally clogged up entirely from a gradual calcium build-up. This happens quite frequently. Close the main valve on your water plumbing, remove the saddle needle valve, and check for blockage. If blocked, try to clean it out. However I would recommend simply replacing it with a new needle valve which can be purchased at any hardware store for just a few dollars.
2.. The control module in the icemaker is malfunctioning. If so, a replacement module can be purchased and installed. However, given the cost of that module, I would recommend simply replacing the entire icemaker unit for just a few dollars more than the module cost.
2. The water fill valve, located near the bottom rear of the refrigerator - (on most models) - is either malfunctioning or its screen filter is totally blocked. In either event, that water fill valve should be replaced. The replacement cost of a water fill valve is relatively modest.
Jul 15, 2009 | Refrigerators
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
