Question about Garden
I need a user's manual for a Husky Portable Air Compressor, model FP207000DB
RCtech
  • 55 Answers
SOURCE: manual for husky air compressor ''easy to go''
For what it's worth Compressors are intended to be turned on and forgot (except for the noise). just for grins lets assume you have the stapler and air hose. you need to hook up the air hose to the compressor there usually is one or to either couplers or npt fittings (threaded). attach the hose to the compressor and using a quick coupler (prefered because it allows the gun to swivel) connect the gun to the hose. turn on the compressor and wait for it to build up pressure and *******. at this point you will need to locate the regulator on the compressor. it will be a knob next to one or two dial gages. crank the regulator a quarter turn either direction while watching the gages. It (one of them) moved either up or down . now you know how the regulator works and your almost a contractor. on to the stapler, load it and find a bit of scrap (what your working on would be best.) now shoot a staple into something and see if it goes in far enough or to far. adjust the regulator to compensate. do this until one of three things happens A you find the right staple depth B the compressor kicks on again, wait for it to turn off C you run out of nails, beer or intrest in the project. once you have found the correct pressure for your needs. you may fire at will you don't need to wait for the compressor to cycle while running the stapler just during set up. now your a contractor go have a beer.
just a last tip if you find you don't have the correct couplers home depot, harbor freight or amazon (online) are great sources for parts.
good luck and mind your fingers
Rob
Posted on Dec 10, 2008
digritz
  • 530 Answers
SOURCE: husky air compressor/1.5 hp
Compressors pull a lot of juice that is why they come with a large power cord. If you use a small extension cord with it it will easily pop a breaker. So first check all your breakers. Second thing is check your manual to see if you have a reset switch on you compressor, as most do. It should be a small, red switch (rocker or push button type), located between the pump motor and compressor switch. The third is a long shot, check to see if the bleeder valve is functioning correctly. It will be the small copper tube running from the pump to the switch. Just make sure the small lever is free to move.
If this fails to resolve the problem then it is probably the main switch itself. That is a warranty issue. If it's out of warranty then your going to have to either repair or replace the switch yourself. Please feel free to ask for help if you need it in latter case.
Posted on Jul 29, 2009
SOURCE: need any user and -or service manual for delonghi PAC -75 U
Here is the manual
http://www.appliancefactoryparts.com/content/pdfs/123150.pdf
Posted on Jun 29, 2010
  • 23 Answers
SOURCE: need manual for husky air
I have the manual in PDF, but no ability to upload to this site. I just uploaded the one I got from the MFR to http://powertool.manualsonline.com/ex/product/headline/m/husky/d/air_compressor/p/41004 but it's not posted yet. Call 877-888-3872 and they'll email it to you if the link doesn't work.
Posted on Apr 18, 2011
SOURCE: Need Manual for Husky Model 41214 Air Compressor
You can get the manual for model 41214 from my dropbox area:
http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
http://db.tt/vQycqXIW
Thanks,K
Posted on May 14, 2012
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
How do you replace a belt on ***** air comprester
Most modles you can either loosen the pump or the motor and slide them together. the belt should roll right off.
Sep 15, 2014 | Husky Air Compressor. 2 Gal. Portable...
Husky Manual for TF291201AJ
Go to http://www.chpower.com/manualsearch/ (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
Oct 16, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Thanks,K
Dec 20, 2009 | Air Tools & Compressors
Husky Air Compressor has rattlling noise!
buddy im an engineer on these machines for 30 years and when this problem has occured believe it or not but it cheaper to buy another pump unit or compressor plus its the hardest job getting the crank out so your choice bud
Nov 16, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
