Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
The blower on my eletric heater will not come on i try changing the fuse but it kept blowing the fuse hen i turn it on maybe not enough fire in da fuse
    Master:
    Sergeant:
  • 449 Answers
You need to replace the motor
Posted on Sep 08, 2010
Cruise control doesnt work the light doesnt even come on
Fuses are a great place to start, if not fuses the actual cruise control switch may be to fault. Rear heater do you get heat out the front and if so is there a fuse for a rear fan maybe a blower.. Let me know
Mar 28, 2014 | 2003 Dodge Durango
2002 venture heater fuse blowing out
You may have a bad resistor or blower motor, a quick test would be to remove the connector from the blower and then turn key on and turn controls to all blower speeds and if the fuse blows then resistor is bad, if the fuse does not blow then reconnect the blower and try the settings again and if fuse blow then blower is bad. good day
Nov 16, 2012 | Cars & Trucks
A/C and Heater Problem
Well,you eliminated the resistor,so it probably means the blower motor has shorted out.Either that or something has gotten into the blower wheel and jammed it. If you can bypass the resistor and just put 12 volts into the motor,do it.But don't hold it long,as a direct short can cause a fire without a fuse to blow for safety.
In other words,prepare to buy a new heater blower motor. don-ohio
Nov 05, 2011 | 2000 Ford Focus
In my 1994 1500 Chevy pickup the heater blower will not work. Need to troubleshoot.
There is not enough information to answer you question effectively. Is your heater blowing cold air or is your blower motor not working? A tell-tale sign of vehicle blowing cold air is bad thermostat. Also, check your fuses under the dash first and fuse relays under the hood before proceeding with the thermostat change. A worst case scenario could be your heating/cooling controls have malfunctioned.
Jan 04, 2011 | Chevrolet 1500 Cars & Trucks
Heater blowing slightly warm air, but certainly not hot enough for pa winters. what should i try to fix first?
You may have to replace your heater core . Heater cores are kinda like you outside ac unit and if you stand by it you can feel all the hotter air blowing from it to the cooler atomosphere!!!! So basicly your heater core are alumminum fins that your blower pushes recycled heated motor air through', and into the cab . Maybe the blower is weak . Check your fuses and hoses!!!!
Dec 16, 2010 | 1996 Jeep Grand Cherokee
Everytime i turn my heater on heater on works and blows fuse?
fuse blows. unplug heater blower motor turn ignition on, turn heater on, does fuse blow? if not need to replace heater blower motor
Feb 10, 2010 | 1995 GMC Jimmy
1998 Isuzu Rodeo is having issues.
check to see if AC and HEATER blower motor is getting power .if yes replace blower motor.if no you have problems in relay- fuse- or ac and heater switch is bad.for sun roof check for power at switch if yes sun roof eletric motor need replace.or sun roof in a bind.if no power to sun roof switch.blowed fuses and bulbs or turn signal switch is bad.
Jun 21, 2009 | 1998 Isuzu Rodeo
Fuse keeps blowing on 2004 Jeep Grand Cherokee
Your fan seems to be drawing way too much current, common with fan motors of all kinds when they are going bad. It will still blow, but hot wires and blown fuses in the normal circuit indicate you have an excessive load in the circuit. Fan motors create this condition regularly, but are often ignored since they are "still blowing."
Here's a cheap, easy way to test my theory:
Try a new fuse, the proper amperage, but leave the blower motor unplugged at the blower itself. That will tell you in a few rides if the blower was the culprit. (Which it most likely is.) I bet your #20 fuse will stop blowing and no more smoking pink wires! Hope this helps. Remember, blower motors are cheap, traffic tickets and dash fires are not. The blower motor draw is the logical thing wrong with this picture. Good LUCK! TT
Jan 28, 2009 | 1999 Pontiac Grand Am GT
Blown thermal fuses
I would think not. The MAIN cause of that fuse blowing is lint build up. Turn the dryer on and put your hand on the outside of the vent duct. Is the air blowing hard? If so, you will probaly be ok, if not maybe your blower wheel needs to be replaced...
Dec 15, 2007 | Whirlpool LER5636P Electric Dryer
Heating & Cooling Logo
170 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
