This problem should be removed because:
Problem with Printers
what is waste toner.
Solutions (2)
Best Solution
We've printed for years using gallon jugs of waste toner nabbed from Quick Print Shop* dumpsters. We just pop the white plug on our cartriges, fold a paper plate into 4ths, snip the tip to make a funnel, and dump it in a half cup at a time!
*Names changed, LOL
I just emptied the cyan waste cartridge of our HP COlor LaserJet CM1312nfi and was considering reusing the toner, but can see that the color of the used toner is dramatically darker than the new toner. I believe when the residue is on the drum, before being swept, it is lightly 'burned' and therefore darkened. I now understand why you can reuse toner from the Black toner waste cartridge, because it doesn't matter the color. I would imagine you might be able to use the color, too, but the final colors would be duller than using fresh. I also think someone should remind toner recyclers to use caution when refilling as the toner in it's powdered state is very unhealthy. I believe toner dust has been classified by the FDA a class-A carcinogen. Use a mask, wipe down loose particles using a dust cloth & wash hands after! Good luck all!
waste motor error
i have the message waste motor error how can i fix it?
how do i replace the
how do i replace the waste toner box on the konica minolta
replace waste toner tank
replace waste toner tank Does it mean that the toner is already used
Waste toner gets full before toner runs out
On our Kyocera FS-4020DN, the waste toner gets full a long time before the toner runs out. Is this normal? Do we need to buy separate waste...
waste motor error on samsung
waste motor error on samsung clp 500
Add Your Solution
Cnecting to a computer
Is there a way of connecting my Samsung SCX 6220 copier to my computer?
Epson AcuLaser CX11nf E521
Service Request E521 on my Epson CX11nf printer. Need help
My Pixma mp830 will not print black text. What do...
I have replaced the large black cartridge several times, but no help. Have done deep cleaning several times with no...
How to access a network printer found in different...
I've connected a network printer to my workgroup network and the gateway for it is firewall (untangle). I...
Fix-O-Meter
13,741
13,741 people viewed this problem
- 21 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Printer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
