Question about Copystar CS-2030 Copier
No power to dp unit - Copystar CS-2030 Copier
  • 113 Answers
Try to enable partial disability by using simulation 906
Posted on Sep 09, 2010
I have the tascam dp-02 digital recorder . It's was shutting down and I accidentally unplugged the power cord before it turned off . Now when I turn it on it just stays on a load screen . I'm wondering if...
You could try performing a factory initialization - but note that initialization of the Tascam DP-02 erases all recorded data from the drive.
To perform a factory initialization of the DP-02 turn the unit off. Hold the Up Arrow and Track Edit while powering the recorder on. You'll get a confirmation screen and then press the Yes/Enter button.
good luck
Feb 27, 2018 | Audio Players & Recorders
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator light....you'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Feb 28, 2014 | Tascam Digital Portastudio Dp-01fx/cd
How do i fix the mount error, please power off.... on a tascam dp-02 when i turn it on?
The only solution I know of is: turning off the unit, then simultaneously pressing Track Edit, Cursor up, and power button until the unit asks "are you sure?" This will unfortunately erase the hard drive.
Jun 29, 2010 | Tascam Dp-02cf Digital 8-track Recorder
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Need to know how to use mic with dp-01
First you'll need to know if your mic is dynamic or requires phantom power. The DP-01 does not provide phantom power, but the DP-01FX and the DP01-FX/CD units have the option of turning on phantom power for their two XRL mic jacks. The DP-01 simply has 1/4" jacks for mics. Typically if your mic comes with a 1/4" plug it will be dynamic, but that isn't always true.
Plug it into the mic/line jack in the front of the unit and turn up the input volume knob. Then depending on which of the two inputs you used you'll have to press the Assign button (A or B) and then the rec button over one of the tracks and turn up the track fader. You'll also need to insure that the master fader is turned up and you should then be able to see the meters moving when speaking into the mic and hear the output in your headphones.
To record simply press the rec button on the assigned track again (it will light steady) to arm the track for recording and press the play and record together.
Hope this helps.
bd.
Jan 08, 2009 | Tascam DP01 All-In-One Recording Package...
(need more tracks) dp01
I'm guessing that you're asking whether the mixer needs phantom power to the mics in which case the answer is that you wouldn't need power there if the mic preamp is providing it already. You'd just plug the mixer's main 1/4" outputs into the DP-01s 1/4" inputs. The 1/4" inputs on the DP-01 are not powered anyway, only the XLR jacks can be powered by turning the phantom power switch on.
Apr 02, 2008 | Tascam DP01 All-In-One Recording Package...
D-Link DP-300U
The DP-300U can be accessed with the password SYSxxxx, where "xxxx" is the last four digits of the unit's MAC address. The MAC address can be found printed on a sticker on the bottom of the unit.
Mar 04, 2008 | D-Link DP 301U (DP-301U) Print Server
Tascam DP01 wont get past please wait screen
Usually an indication of bad sectors on the hard drive. This can be caused by bumping the unit when it is running, excessive vibration, a power failure while it is on, improper shutdown, or expoure to a strong magnetic field like having a subwoofer too close or an intermittent faulty power supply.
Your options are to return the unit (if it is still under warranty), or if not to open up the DP-01, remove the hard drive, connect it to a PC and perform a low level format (or take the drive to your nearest PC repair shop and have them reformat it).
Unfortunately you'll lose any data that wasn't backed up, but this should bring back your DP-01.
Jan 05, 2008 | Tascam DP01 All-In-One Recording Package...
Error message on copier
That is a laser unit error. If resetting the machine's power doesn't clear it up, then it means the laser unit is dead/dying. If that's the case, your only choice is to replace the laser unit.
Oct 04, 2007 | Panasonic Workio DP-150PA Copier
Copystar CS-2030 Copier Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
