Question about Kenmore HE2 Plus Front Load Washer
I am getting a f-21 reading on my washer it says to chek pump filter for blockage where is the pump filter?
  • 15,935 Answers
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
My washing machine has a code e21 what do that mean
Please read description carefully about error code
Logik Washing Machine Error 21: "E21"
Error Code Definition: Washer has not drained in allotted / time washer not draining.
How To Clear Error Code:
-Check that filter is not blocked or kinked
-Check drain hose is clear of any blockage or kinked
-Check wires to drain pump
-Check drain pump is not faulty
-Check level sensor and switch
-Check wires to level sensor
here is link for more about your all error code which will may helpful in future, LOGIK Washing Machine Error Codes How To Clear
here is video which helpful regarding solve and understanding error.
Mar 16, 2017 | Washing Machines
What is code f 21?
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Dec 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I get the cap off neutral drain assembly to clean out drain lines without damaging it . i need to clean out lines I believe they are clogged. It is displaying F-21
To check the pump filter for blockage, remove the panel underneight of the door,the pump will be in right lower corner,unscrew the big(about 4 inches diameter) white cap just a little and use towels to catch water that comes out of it,when all water out completly ,unscrew and check for blockage.
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2Plus White Front Loader. Drain pump seems weak, wet clothes, and f-21 flashing..???
F21 error code is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Kenmore HE2 Plus Front Load Washer
What does f-21 means when it blinks and your washer machine stop
Kevin
Feb 15, 2011 | Kenmore HE2 Plus Front Load Washer
Mine keeps flashing F 21 what does that mean?
Hello
Kevin
Nov 09, 2010 | Kenmore Elite HE5t Washer
F-21 error code, washer stops
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris.
Thank you !!
Jul 13, 2010 | Kenmore HE2 Plus Front Load Washer
My washer reads "F-21"
Thank you !!
Jul 05, 2010 | Kenmore HE2 Plus Front Load Washer
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Dec 23, 2008 | Washing Machines
F-21 error, washer not draining
I have had this code three separate times. The first time service man came and cleaned out the filter. This is behind the lower front panel and can be removed by hand. The cartridge style filter is located at the pump in the lower right of the unit. Have something available to catch the draining water as you loosen the filter. The second time I received this code I found a blockage in the drain hose at its bend. The third time no hose blockage, no filter clogging, but the pump impeller was jammed by an elastic strap that had made it through the filter. I removed it through the supply side of the pump seen after filter is removed.
Feb 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
77 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
