Question about JVC AM FM CD DET FACE CAR STEREO
Yesterday my cd player has no power i took it out check the wires they are all connected checked the fuse on the unit and thats not it so i think it is the fuse for the car stereo. but i dont know which fuse it is for my 206 jeep liberty
    Renaissance:
    An user who is expert in 3 categories / brands.
  • JVC Master
  • 2,226 Answers
It might be a good idea to just go ahead and test all the fuses, both in the car (usually under the dash or in a kick panel) and under the hood.
Posted on Sep 07, 2010
New Kenwood Cd Player won't work
Hello! Even though you believe the wiring is not the problem...The wiring, more times than not, is the problem...When you first turned the unit on the volume maxed out at 20...I believe you have a wiring error in the ground portion of circuit...
Here is the wiring for your vehicle...
POWER
Illumination = Gray
Constant +12= Orange/Black....Memory lead
Switched +12= Yellow...Power-on via ignition
Ground= Black...Outside metal case of CD
Must read zero ohms to
chassis and negative batt.
terminal of vehicle when
connected...
Check your connections with a voltmeter...
SPEAKERS
FR+ = Dark Green
FR- = Light Green
FL+ = Tan
FL- = Gray
RR+ = Dark Blue
RR- = Light Blue
RL+ = Brown
RL- = Yellow
The spark means that +12 volts was tied to the case of the unit and when the case touched chassis ground it caused the spark...Lets make sure you have checked all the fuses..I'll give them to you in a minute...
With the unit set on the carpet... Place one lead of an ohm meter on the case of the unit and the other lead on the vehicle' chassis...You should read a dead short which proves that the case of the unit
(via wiring ) is connected to proper ground...I would bet that it is not...Here are the fuses...
Radio fuse= 10A...This powers the Yellow ignition lead...But it also has an in-line fuse that carries +12 volts to the steering wheel controls
(if equipped)...Last fuse is the Int lamp fuse 10A which powers the Orange/Black constant +12 lead...
Wire as given...provided that the unit is unharmed...
your tunes should return...Let me know how you make out.....
Guru...............Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
May 27, 2010 | Car Audio & Video
I tried to install my cd player and the ground hit another wire i think and now i have know power to the radio and i checked the fuse and did not blow
check the fuse on your auto, to see if that is ok, the one that powers your audio system, and also check the fuse/fuses for the radio unit itself.Alternatively, the unit has died
Oct 21, 2009 | Sony CDX-GT300 CD Player
No power to front panel but have power to main unit.
You Have constant power (yellow wire) but your Acc wire or switched power wire (RED WIRE) does not have power. Check the connection of this wire. You most likely have a blown fuse in your vehicles fuse panel.
May 19, 2009 | Sony Xplod CD Player w/MP3 Playback...
Kenwood head unit not powering up help please.
find your remote wire. it would help to know the type of car and the kind colors of wires your using as your 3 main wires.
normally in most chevy and fords they are yellow 12 volt.
black as ground.
red sometimes even a tan as your remote start.
deff check your start
May 09, 2009 | Kenwood KDC-W6027 CD Player
Have a in dash jvc kd-sx750 cds player that won't power on
if you had the speakers hooked up wrong it would just make a crackling sound when it rubs on a surface. if your vehicle has a factory built in amplifier somewhere you may have to hook up the remote turn on wire to the wiring harness to tell it to turn on.
also make sure your illumination and dimmer wire are hooked up correctly if it doesnt display any images on the screen. and if for some reason you think its shutting off because of crossed wires maybe check the ground the batt and the ignition wire ,or the red black and yellow wires. usually when something major like those three wires get crossed it blows fuses in the car taillamp fuse stereo batt fuse ect. check all those .try resetting the deck of the car battery thats all i can think of now.
May 06, 2009 | JVC KD-SX750 CD Player
Panasonic R 805e with cd shuttle
I had a similar sounding problem with my stereo and got the following response here...
"It sounds like a bad ground wire connection-you want to check the rear of the head unit and make sure that your wire harness is very secure to the unit clip the ground wire and run your own ground wire to somewhere-anywhere where you can safely ground that wire to the chassis I actually attached my ground to the rear of the cigarette lighter because you KNOW that it has a dam good ground to manage all the current it takes to light them coils orange like that"
I took the advice and it worked out great! Give it a try and see what happens.
Apr 05, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
Dec 14, 2008 | JVC AM FM CD DET FACE CAR STEREO
I have a problem with the CD player turning on.
sounds like u got a bad unit if only certain things get power then it sounds like an internal problem
Jun 25, 2008 | JVC KD-G200 CD Player
** power
There is usually a fuse on the back of the unit. Did you check that? There may be a power supply issue to where ever you took power from? Maybe not a constant or "breaked" tap point. Go over the following site and see if it helps. If all else fails, the unit could be faulty. Go back for warranty.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 09, 2008 | Panasonic CQ-DFX302U CD Player
NO Power
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key one. If only one has power the radio will not work. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Sep 03, 2007 | Dual XD-7500 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
75 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
