Question about Goodman GPC1342H21A Air Conditioner
Blower fan does not come on. everything else does.
    Master:
    Sergeant:
  • 449 Answers
Chech the blower motor
Posted on Sep 08, 2010
Interior fan has stopped but air con compressor starts when fan is switched on
look for blower motor. if not the case, the blower could just be broken. it can happen once the vehicle gets close to 10 years, but is usually preceded by a noise in the blower. most everything other than the blower, in the ac system, goes back to the mc unit.
Dec 29, 2014 | Cars & Trucks
Fan blower is on full and can't switch it off
The Blower Resister Unit Needs Replacing It Sounds Like. The Resister Is Located On The Passenger Side Kick Panel By The Blower Motor.
May 17, 2013 | 2006 Hyundai Santa Fe
Honda pilot 2007 blower fan making noise blower fan was replaced once still making noise
Either its developed the same fault or the fan motor bearing has failed, needs greasing or, if there's a belt, the belt is slipping.
Feb 22, 2012 | 2008 Honda Pilot
The fan is not coming on. Everything else seems to be running. Smelled something burning from the fan area. Main fan blower turns by hand.
Could be motor could be circuit board could be capacitor. Can u turn Thermostat fan switch to on and start blower
Jan 16, 2011 | Weather King Heating & Cooling
Heater/defrost/ac does not blow in my 2006 tacoma. worked this morning, parked at work, came out half hour later and would not work.
what has most likely happened is that a fuse has blown that is in your blower fan circuit. Check your owners manual, and see if there is a fuse to that system, if there is, check and see if it is blown. If it isn't, then the problem could either be your blower fan itself, or your blower motor resistor. Generally, when the blower fan goes bad, no speeds of the fan work. When the Blower motor resistor goes bad, usually only 1 speed of the fan works. Try the first suggestion i gave, and it everything checks out in the fuse box, then try all of your fan speeds. If one works, you need a blower motor resistor, if none work, then it is most likely your fan. Let me know how it goes and i'll do my best to assist you further. good luck.
Jan 13, 2011 | 2006 Toyota Tacoma
Have a Bryant Pkus 80v. Everything fires up but
Check to see if fan is hot. If it is check capacitor. The silver oval component attached to blower housing. If motor is not hot you have a bad fan board or fan switch, Check above burners and you will see a lower limit switch and above that a fan switch. If you do not see a fan switch. The problem is blower control on board. You will have to replace board. Rus
Mar 21, 2010 | Heating & Cooling
HOW DO YOU CHANGE THE HEATER BLOWER MOTOR?
YOU NEED TO TURN OFF RADIO TO KEEP FROM LOSING RADIO CODE.REMOVE NEGATIVE BATTERY CABLE.THAT WILL DISABLE AIR BAGS.WAIT 30 MINUTES.SO THE AIR BAGS CAN DISCHARGE.THE BLOWER MOTOR IS LOCATED ON THE PASSENGER SIDE OF VECHICLE UNDER THE INSTRUMENT PANEL.WHEN REPLACING THE BLOWER MOTOR.YOU HAVE TO REMOVE THE SQUIRREL CAGE OR BLOWER MOTOR FAN.BY REMOVING THE METAL STAR CLIP RETAINING THE FAN CAGE TO THE MOTOR SHAFT.REMOVE THE FAN BY PULLING STRAIGHT OUT.TO INSTALL BLOWER FAN TO NEW BLOWER MOTOR.INSTALL THE FAN CAGE ONTO THE MOTOR SHAFT .ADJUST THE FAN CAGE TO GET A CLEARANCE OF 0.30 INCH TO THE MOTOR MOUNT PLATE.INSTALL EVERYTHING VISA VERSA.BESURE TO BUY A REPAIR MANUAL.SO IT CAN SHOW YOU WHERE ALL YOUR PARTS AND SCREWS ARE LOCATED. WARNING IF YOU HAVE ANY DOUBT ABOUT THIS TASK.LET THE DEALERSHIP DO IT.
Oct 13, 2009 | 2005 Chevrolet Impala
MY HVAC fan stopped blowing. Checked all the
Check the blower motor speed control resistor pack is ok.
(The resistor pack is usually located in the blower fan ducting in the air flow).
Check condition of electrical connection terminals on the blower motor circuit - these terminals pass considerable current and over time may fatigue overheat and loosen.
Check operation/replace any blower motor control relay,
Check the blower motor will run if +12v directly applied to the blower motor.
Check operation of the blower motor speed control switch is ok.
Oct 08, 2009 | 2003 GMC Sierra
94 gms safari van heater blower not working
This van has a resistor under hood for the blower motor and is the blower motor getting power to it
Jan 17, 2009 | 1989 GMC Safari
BLOWER FAN NOT WORKING PROPERLY
I had the same problem change your blower motor resistor.
Nov 13, 2008 | 2006 Chevrolet Trailblazer
Goodman GPC1342H21A Air Conditioner Logo
82 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
