Question about HP PhotoSmart 7550 InkJet Printer
HP 7550 PhotoSmart Printer prints photos with an unpleasant green hue.
Photos are printed with an inaccurate pale green hue. This happens whether printing from either the computer or from the memory card in the printer.
Philip Mayfield mayfield@telus.net
  • 3 more comments
  • Anonymous Dec 07, 2008
    I have exactly the same problem. the green haze seems uniform over the images.
    urbanfaubion@frontiernet.net
  • moosie820 Dec 22, 2008
    I have the same problem.  I've recently replaced all three cartridges.  I tried printing gray scale, and it was worse yet!  (My children looked like aliens!).  Printing a gray scale photo using only the black cartridge produced a nice B& W print.
  • 7550 problem Jan 23, 2009
    Same green problem. It prints great when using regular/copy paper, but when using photo papter (no matter what brand or type) it prints green. I've deleted and reinstalled the driver many times and it once did fix it long enough to print one job, but then it came right back. The only way is to "trick" it to print in full color spectrum is to put a piece of regular/copy paper on top of the photo paper and ask it to print 2 copies. Then you get a fantastic print job. But what a waste of ink! and what a headache!!
  • cathy9887 Jan 26, 2009
    Me too.. I've been having this exact same problem on my HP 1510xi all-in-one. It started 2-3 days ago, right after I changed the color cartridge. I've had the printer for over a year & prior to this, I've never had an issue. I have tried cleaning the cartridge, aligning it, & using different brands of photo paper (both HP & Kodak).. they all still come out very green. I checked all of my printing settings & everything is set correctly. On a test print, I printed a photo on regular paper, which came out perfectly normal. Without closing the print box, I clicked "BACK" and reprinted the exact same photo on HP photo paper... it printed green.
    Has anyone had any luck with a fix?
    Thanks!!
  • Anonymous May 03, 2009
    I have exactly the same problem. Was printing a 100-photo job and halfway through, all images turned green. All cartridges have plenty of ink. I cleaned and aligned printheads. No change. Then I inserted a photo in to a Word document and printed on copy paper. Looks fine. This is extremely annoying.
  • 3 Answers
If it's a B&W or sepia photo, and you wanted to print B&W or grayscale anyway, pull the color cartridge (assuming a 2 cartridge system). I did that with my HP DJ 5440 and it works perfectly.
Posted on Aug 01, 2009
My photos are green tinted.
Hi ikachooxs2, Here's a link from hp website for print quality issues related to this model.
Aug 05, 2011 | HP PhotoSmart 7550 InkJet Printer
Poor print quality
go to printer properties and select the advanced tab check the image quality
May 07, 2010 | HP PSC 1410v All-in-One Printer
Printing with a green hue
photo r300 printer is printing coulor photos ok but when i use adobe 7 i turn my pictures into black and white and then i hilight some coulor into the photos good prints but now the prints have a green hue to them ?
Oct 22, 2009 | Epson Stylus Photo R300 InkJet Printer
HP D7260 can't print color in black & white only - greenish hue
I am having the same problem, printing photos I took of the moon thru my telescope. Any solutions?
Jul 01, 2009 | HP Photosmart D7260 Printer
Green tinged photos on photo paper normal color output on plain
Assuming a 2 cartridge system, and you want B&W or sepia, pull the color cartridge and print away! Works for my HP DJ 5440.
Jun 30, 2009 | HP PhotoSmart 7550 InkJet Printer
I have a Canon IP 1800 PIMXMA printer. I'm not
What paper are you using.
Use canon paper and EZphoto print .
Tou will be amazed .
These printers mix the 3 colors to make a black in photos.
So if you have shadows or black in the photos they will lack contrast
Jun 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
Hp pro b8350 will not print colours seen in pictures
discovered print cartridge was faulty. no yellow was coming through.New cartridge solved problem
May 01, 2009 | HP Photosmart Pro B8350 InkJet Printer
HP Photosmart 7550 - Full Page Photo Printing Jams at end
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | HP PhotoSmart 7550 InkJet Printer
Hp photosmart 7350
The 7550 takes three cartridges 56(black) 57(tri-color) and 58 (photo).
If you replace the 57 but the 58 is also empty and still in its slot - you get green tinted photos.
So, check to see if you have the 58 photo cartridge still installed, and if it is out of ink. If so - remove the 58 - the printer will then default to "reserve mode" and you'll get better color.
Dec 16, 2007 | HP PhotoSmart 7350 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
1,179 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
