Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
We were having trouble with one side not freezing so we replaced the shaft seals and replaced a board on the side that wasn't freezing. It now is saying Maintenance due Shaft Seal. is there still a problem or do we need to reset something to get the message to disappear.
    President:
  • 1,618 Answers
You need to go through the menu and tell the machine that the maintenance is done, hold down the middle button to get to the menu, then follow on screen prompts and navigate to shaft seal maintenance.
Posted on Sep 08, 2010
Taylor model 754-27 soft serve machine getting water and soft serve in side tray on the the side of the machine. never happened before.
It's either:
A. The drive shaft boot seal - 032560 Boot Seal - You can buy them individually or as part of the tune up kit. They are normally replaced quarterly. Inspect this part when you take the drive shaft out for cleaning. It's very important that the drive shaft comes out every time you clean the machine and that you pack lubricant between the seal and the shaft.
B. The Shell Bearing - Taylor 031324 Replacement Rear Shell Bearing This is the metal sleeve that the drive shaft goes through in the back of the freezing cylinder. They wear out over time, they usually start to "mushroom" out grind down the boot seal.
031324-4 -5jpt2eusobswb402obrm5sjf-2-9.jpg Email me if you need a part or more help.
tex@softserveparts.com
Jun 07, 2017 | Taylor Ice Cream Makers
Replace rear seal (drive shaft) on manual trans and started leaking badly
Drive shaft have only one seal and seal rear side on metal bush
1 jak up littil gear box because after shaft remov ing time oil no feldown
2 remove drive shaft rear bolt
3 mesher drive shaft seal touching area
4 mesher drive shaft Bush touching area this area damage want send machine Shoppe bush cover and drive shaft that time send seal also
Damege change that Bush also
Apr 25, 2016 | 1998 Isuzu Amigo
I have a davey torrium xj70t-0 which is leaking at the discharge end only when the pump is on. I figure it is the seal and have removed it to replace but it looks ok. Should I get a new one anyway or could...
If it's not the seal it may be a worn section on the shaft. If it was me and the seal wasn't to expensive I would polish down the sealing surface on the shaft and seat and replace the seal.Not knowing what pressures you are running at it doesn't take much wear on the seal to cause a leak. I hope this helps you and thanks.
May 20, 2011 | Plumbing
I have done that allready,so it should be over the fins in the radator?
Always fill your radiator to the top. and make sure the overflow bottle is full to the high mark( if your model has an overflow bottle). Run the motor and after it cools down top it up again. The reason you do it this way is to make sure there are no air pockets in the head. Gas expansion there will push your anti freeze out of the motor and may damage the head.
It can be said for all motor cycle water pumps that if the engine gets hot it is easier for the anti freeze to leak past the water pump seal before it leaves past the radiator cap to the over flow. It is the steady/constant drip that needs to be addressed. I assume you replaced the impeller shaft as well as the seal. It is possible the seal was damaged during the install or one of the sealing cover o-rings or gaskets is leaking on the cover. If you can not ride safely with the amount of anti freeze loss, you should take the water pump apart, inspect, and consider replacing the seal and gaskets again. If the impeller shaft was not changed consider changing that to if there is any noticeable wear at all on the pump seal contact surface.
Use only non-silica formula anti freeze mixed 50/50 with distilled water. Gm Dexcool or any motorcycle anti freeze should be non silica. Silica content is stated on the anti freeze bottle. Silica scrubbing particles in the anti freeze will damage water pump seals in most Honda's.
Apr 17, 2011 | 2002 Honda CRF 450 R
A friend of mine had the driver side cv- joint replaced and now it is leaking trans fluid does this have a seal
the trans seal was probablu damaged when the shaft was replaced, they can be replaced without too much trouble
Jul 27, 2010 | 2002 Chrysler Town & Country
My fridge is freezing everything I have the control board replaced and it didn't fix it what is causing the fridge to freeze
an overworked motor is normally the problem.
could also be a faulty thermostat.or even a leaky door seal.try the cheapest solution first.....
Jun 18, 2010 | Frigidaire FRS26H5AS Side by Side...
Leaking anti freeze and metal scraping sound coming from front passenger side of car. just replaced radiator 4 months ago. no white smoke out of tailpipe
It sounds like you need a water pump. When the bushing in the water pump shaft wears out it makes a horrible grinding marbles together kind of sound and coolant leaks past the shaft seal.
May 12, 2010 | 2001 Nissan Altima
How do you remove the rear axle to change the axle seal, from a 2004 Coloraro?
remove the center cover facing the rear of the truck. you will see side gears with the shafts axle end at each side gear. a C clip will have to be removed from each shaft at the end of each axle. Then remove the wheels and pull out the axles
Feb 06, 2010 | 2004 Chevrolet Colorado
My ultra 2 is not freezing anymore and screen says torque error. how do i fix it?
Check the back of the machine where the big plastic cover is, you will have to remove the 2 screws back there, and the 2 hoppers as well as the metal platform. When you remove the cover you will notice a mountain of product covering the shaft and the little CPU board back there, clean replace shaft seal and bushing and make sure that the red and white lights on the board have no product on them.
Jun 29, 2009 | Bunn Margarita Machine Ultra 2 Slush...
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
1,110 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Kelley Hopper
Jerry Greenberg
Jerry Greenberg
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
