Question about Nokia 6600
What can i do help me plzzzzzzz!!!!!!!
Sir when i format my memory card & i restore all the certain files then when i return my memory card in my nokia6600 it say that my memory card hav corrupted ??help me to restore all my messages !!!plzzzz
    President:
  • 1,257 Answers
If you are trying to format it through pc ,select the fat partition during formatting since memory card only supports fat partition .so first try to format it in mobile only...you will see a option to format memory card ,when the formatting is over .you can copy the contents to the memory card..
It will be highly appreciated if you could take a minute and provide us your feedback...........Thanks
Posted on May 14, 2008
Memory card corrupted
Hi
The only option after corruption of memory card is formatting it. But, after formatting certainly you will lose some data. Then you can recover lost data by making use of memory card recovery software because using this software I was able to recover data from formatted transcend memory card.
For more details visit - http://www.unformatdata.com/recover-data-from-formatted-microsdhc-transcend-memory-card.html
Jul 21, 2012 | Nokia E72 Smartphone
I want recover my photos in my 4GB SDHC Sandisk Memory Card
click start control panel administrative tools computer management disk management right click on your 4gb drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
i found best results tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
May 07, 2012 | SanDisk 4GB Secure Digital High Capacity...
Sir i want to format my phone memory of nokia 6303ci. my phone memory is showing almost full. i m restoring the set but not recover al my 55 MB memory
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
Jul 20, 2011 | Nokia 6303 Cell Phone
MY SAMSUNG U600 MOBILE PHONE LIMITED SERVICE PIZZZZZZZZZZZZZZ HILP ME PLZZZZZZZ
Possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Apr 12, 2011 | Samsung SGH-U600 Cellular Phone
Sir I forgot my nokia 7210 supernova mobile. 12345 is not working. pls. help me for restore factory. How to crack the code
Remove the battery and the memory card from the phone,check for corrupt files on the memory card with a scan on your PC- card reader. Remove and format if necessary. Reset battery and open menu settings to open link to restore to factory settings- now type 12345. If this wont work then you must reinstall the software. check with Nokia care.
Jan 20, 2011 | Nokia 7210
Sir, My Nokia 5200 phone restart when Music files is played from Memory card, and also when file is copied or recieved through bluetooth or captured picture to memory card. This problem is occured when...
hey
phone restarting could be due to many reasons. virus in the phone, software reset problem, etc. here you can try doing it by removing the memory card from your mobie and master format it, then keep the mobile inbuilt memory to the minimum and then try using the music player and transfer files if still the problem continues then try formatting the phone in a service center.
bye
Sep 26, 2010 | Nokia 5200 Cellular Phone
P3400I
Sir,
In My HTC P3400i the start menu containt application and setting are removed how to get them back.
Please provide solution.
URGENT.
Mar 19, 2009 | HTC S710 Smartphone
How can format the phone memmory of NOKIA 3230
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Feb 20, 2009 | Nokia 3230
MEMORU CARD CORRUPTED
try by restoring handset once a time or else memory card is corrupted..change it....
Oct 18, 2007 | Nokia N70 Cellular Phone
Nokia 6600 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
