Question about Coleman Heating & Cooling
Wiring correct way to connect the wire from the connecter to the compasertor
    Master:
    Sergeant:
  • 449 Answers
Not a job for a novice you can get seriosly injered or even blinded
Posted on Sep 08, 2010
Making random loud bursts.
Connection wires? If your connection wires aren't that great or just won't plug in correctly or are not connected correctly the sound jumps in and out with random loud burst or sometimes a really annoying scratching sound.
make sure nothing is obstructing the plugs (going in), re wrap your wires(if you have the type of speaker with the loose wires you wrap yours) or upgrade your connection wires/plugs.
This may help? :)
Oct 29, 2013 | Klipsch Audio Players & Recorders
Wiring diagram avh-p6300bt
i have a pioneer AVH-P6300BT but im not sure if i have i connected correctly with my amp. my speakers just dont seem to be pushing the power i know they can. so for starters which wire is the remote wire? i have the RCA's connected to the one that is labeled"Subwoofer output" is this correct? The wiring diagram also talks about connecting to the violet and violet/black wires for the subwoofers whats this for?
Apr 30, 2012 | Pioneer Car Audio & Video
Would like to replace this switch with a standard light switch, whats the correct wiring connection
PLW01 has 2 wires: Black wire connects to Hot and Blue wire connects to Load wire.
http://lib.store.yahoo.net/lib/aaaremotes/PLW01.pdf
Remove PLW01 and you have Hot and Load wires.
Standard light switch has two brass colored screws, and one green ground screw.
Connect either wire to either brass screw.
Connect bare ground wire to green screw.
Aug 10, 2011 | X-10 X10 Pro PLW01 Standard Toggle Single...
I would like to wire the 60 minute timer to a plugin for my iron how do i go about it the timer has only two wire coming out Thank you mike
If I understand correctly, you have an outlet for your iron.
You have 60 minute timer with two black wires.
You want to connect 60 minute countdown timer to prevent iron from being left ON.
Good idea, and perfect application for this timer.
Your outlet has two insulated wires, one black wire that is connected to brass screw and one white wire that is connected to silver screw.
If you have 2 blacks and 2 whites, that is also covered below.
Here's is how to wire timer to outlet.
1) One black and one white:
Remove black wire from brass screw.
Connect this wire to either wire on timer.
Connect other timer wire to brass screw on outlet.
2) Two black wire and two white wires.
The easiest way to proceed is try one black outlet wire and if it doesn't work then try the other black outlet wire:
Remove one of the black outlet wires from brass screw.
If timer works to control outlet, then wiring is correct.
If timer does not control outlet, then try the other black outlet wire.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 09, 2011 | Woods 60 Minute Spring Wound Timer in...
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN´T SEE THE NUMBERS WHEN I´M IN FROM THE SCREEN, IT´S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
When I wired my utilitech wall timer the lights flash and it makes a clicking sound...
Another fellow wrote in today.
His lights were blinking because he connected the red and white wires together.
Below is the correct wiring for Utilitec, GE, Woods and several other brand timers.
The black wire has to connect to Hot wire from breaker box.
The red wire has to connect to wire going to Load (lights, fan, motor)
The green wire connects to bare ground wire
The white wire is connected with other white wires inside box. These other white wires are usually covered with a wire nut and shoved to back of box.
If you do not have other white wires in the box, then connect white wire with bare ground wire.
If your timer does not work, try reversing the red and black wires.
I am running tests on these timers and can verify that the information above is correct.
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Oct 23, 2010 | Garden
When wiring up the light, blue wire for the light should connect to the black wire in electrical box, correct
connect white wire from light kit to white wire labeled "for light" then connect black wires from light kit filter to blue wire from fan. Use wire nuts to make the connections
Feb 06, 2010 | Hampton Bay 24002 Ceiling Fan
Running 10/3 wire and wiring clothes dryer directly. The dryer does not have a ground connect for the bare copper ground. Can it be connected to the white neutral at the dryer?
NO!! use the green screw on back where cabinet ground goes red to red white to white black to black remove cabinet ground wire and connect it up to white neutral on dryer connect bare ground to cabinet ground screw ..but wouldn't it be better to connect wall plug to house wiring and correct cord to dryer? always hate working on hard wired equipment since a lot of breakers are never labeled or relabeled correctly
Jul 15, 2008 | Dryers
Wire connections for camper
The wire from your brake controller should be blue (if it was wired correctly). It also should be a heavier gauge wire. Typically 10 gauge. Once you have determined the correct wire, check it to see if controller power is getting through the plug. Another common problem is the ground wire not connected (white).
Jul 06, 2008 | 1998 Chevrolet Crew Cab
Heating & Cooling Logo
24 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
