Question about Mitsubishi WS-65511 65" Rear Projection Television
Mitsubishi ws-65511 tv won't turn on - Mitsubishi WS-65511 65" Rear Projection Television
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If the green power light on the front comes on for a second or two and goes out: Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both. Power light will blink a two digit error code: 2 blinks, 2 blinks, pause and it will repeat several times. Let me know if you find a error code and I will tell you what it means. IF this information was something you did not know, rate this solution as very helpful as I do this here for free. SD TECH
Posted on Sep 07, 2010
Hi SD Tech, your post was helpful in figuring out the error code on my TV. I have a Mitsubishi WS-65907 with the same error code, 2-2. Apparently I pulled an amateur move and plugged my DVI to component out of my PC, to DTV-in on my TV. I got static on the middle third of the screen bordered by thin red lines for a few seconds, then it died. Looking inside I see one obvious burn mark (pic below), I wonder if I find a replacement for this board if you think it might fix the TV? Or do I have a bigger problem on my hands? This TV has worked great since 2001. Thanks for any help! -Nealmitsubishi ws-65511 tv won't turn on - 12_12_2011_3_08_25_am.jpg
Posted on Dec 12, 2011
  • 87 Answers
SOURCE: Mitsubishi WS 65511 convergence
Go on line and get an original Sanyo STK 393-110. Next, restore the blue centering rings back to where they were before you moved them. Look at the paint marks on the rings for reference if you are not sure. Replace the IC and check the resistors nearby for signs of overheating and proper value. Also check the fuses that supply the 24v to the IC. The service manual will show you the fuse location and give you the resistor values in the blue horizontal and vertical circuit. Checklist: You need a de-soldering tool or a good quality Dry Wick. Have a small tube of heat sink compound to liberally apply to the new chip. The hardest part will be lining up the double rowed pins on the chip and getting them to seat at the same time. Next, go to the convergence menu and follow the instructions. Good luck! PS you might want to remove the chassis from the cabinet to make it easier. Be careful to unplug the speaker plug and untwist the wire ties from the cabinet. Be very careful, this job is not designed for beginners.
Posted on Mar 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi ws-65511 No power green light blinking
yes the capacitors on the DM need replacing. depending on the chassis some have 4 capacitors on the DM board where as other chassis have 7 capacitors on the DM power supply that are causeing the problem. If you dont know which chassis your has go to this link and leave them an email they can help you figure it out,
http://servicemanuals.vstore.ca/
Posted on May 31, 2008
Slinteriors
  • 8617 Answers
SOURCE: MITSUBISHI 65" RAER PROJECTION TV MODEL-WS 65511
Try to press both the menu button and the input/device button on the set both in together and hold in for 6 seconds to see if the led will blink a two digit blink code, then let me know the two didgit code, and I will try to assist you. Please respond to this same post when replying.
Posted on Aug 08, 2008
  • 4234 Answers
SOURCE: convergence problem
If all you replaced were the ICs, then you need to check the area for small pico fuses that are probably open as well. These are inline with the power supply to the ICs. They may be marked as F9A01 through F9A06. Replace these as needed and update this with your results.
Thanks,
Dan
Posted on May 05, 2009
  • 8457 Answers
SOURCE: HDMI upgrade card available?
No,it for data recovery mainly.Ur HDMI connection it work?If not tries another HDMI cable usally work.
Posted on Aug 27, 2009
I have a mitsubishi ms-65511 and we had a poweroutage for several hours today and now the tv won't turn on and I am getting a continuous green light of death ... HELP
Thats caused by weak capacitors on the DM board which cannot recharge after the power has been restored. Very inexpensive repair . The WS48511 - WS55511 DM repair kit from www.tvrepairworld.com has the capacitors and the CD with repair instructions which should solve the issue of the steady blinking green light.
Oct 11, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65511 Front Lock
Bypass Mitsubishi WS-65511 Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65511 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65511 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Mitsubishi WS-65511 Manual Download
Reset Mitsubishi WS-65511 VChip Password
on May 03, 2010 | Televison & Video
Tip
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
I need the manual for my tv
Download the user manual by pasting the following link in your browser.
http://support.mitsubishi-tv.com/documents/WS-65511
Jul 22, 2011 | Mitsubishi WS-65511 65" Rear Projection...
My Mitsu WS-65511 will not power on. When power is pressed on tv or on remove solid green light comes on for a moment as if television is going to come on and then it just shuts back off. I have tried...
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25.
Apr 05, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Download Mitsubishi WS-65511 HDTV Manual
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
My Mitsubishi WS-65511 won't turn on.
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Feb 22, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
359 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
