Question about Pentair Mastertemp Heater
Remote says my pool is 125 Degrees. The water is cold. Heater will not come on. I'm thinking it is the heat sensor has gone out. What is the correct name so I can order the part and where is it located in the heater. I have a 400BTU/HR Natural Gas 460736
  • 990 Answers
Right you are! The sensor is reading that high so the ignition module is telling the heater not to fire because the water is to hot. You can find this on the water manifold then just follow the wires back to the board. Plug a new one in and run the wires and you will be done.
Posted on Sep 08, 2010
Pool heater throws code h5? smoked
HS
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees.
Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow conditon. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater...
Heater only warms water to 98 degrees
temp sensor or if control box make sure heater set to 104
Nov 27, 2013 | Sta Rite Sr333na Max E Therm Pool & Spa...
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Heater won't start up. display shows 111 degrees but spa is cold
Your temp sensor has gone bad. You will find it on the left side of the water header (Where the pipes come into the heater) It is a small tube with two wires coming from it. Simpley slide a new one into place and plug into the board. Good luck.
Jan 27, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Heats up to 4 degrees and goes no further...Yikes.
Have the same heater, I changed the temp sensor and it fixed the problem. Low PH damages the sensor. I think I paid $25 for the sensor.
Oct 22, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Water Temprature read 126 on heater and will not fire. Pool temp @ 72 degrees. Heater set for spa @ 101 degrees. SR400NA Sta-Rite Heater
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Oct 04, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Pool Not Heating Display Wrong
where the thermostat is located, the pump is not circulating the water
Sep 04, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Temperature reads 125 degrees.
I am not sure if you have solved this issue, or not, but just in case. The problem is the Thermister, or temp sensor. That will need to be replaced since it is reading the water temp at 125.
The Thermister is located on the manifold, left hand side, between the first two bolts. It is pretty easy to change out and this will correct the problem.
Jun 08, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
Pentair Mastertemp Heater Logo
395 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
