Question about Epson CX8400 All-In-One InkJet Printer
How do i override the replace ink? I am just printing black ink and its asking me to change cyan?
  • 286 Answers
SOURCE: Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Posted on Dec 30, 2007
SOURCE: MP830 Cyan Ink won't print
To Fix the stupid Cyan, just unplug the printer, it may take more that one time unplug, its stupid problem, printer needs to reset, I have a full ink of Cyan but it says this "There is more than one Cyan" on the dispaly on the printer, and windows that its missing. I don't know what idiots programmed the printer. but screw them.
for cool stuff check out my site http://www.gagla.com
Posted on May 03, 2008
Basti
  • 1447 Answers
SOURCE: Changed the black ink cartridge but can't print just black
Hi-
Sorry to say but NO you can't print if there are other inks which ae empty, thats one safety features of epson printers to prevent nozzle clogging. change the other ink carts as well for you to continue printing.
Posted on Sep 02, 2008
websnail
  • 419 Answers
SOURCE: My EpsonDX4450 won't print Black ink only when the Cyan is empty
Much as I'd love to say that Epson are being a bunch of "robbing gits" as you put it, in this instance they are actually helping protect your investment. If the printer was allowed to print without a valid ink supply on one of the ink types it would soon fill the printhead with either foam or air. Either promotes clogging. Now, whilst you might be certain that you're using just black, the printer may be programmed to use a small amount of the other colours (depends on the settings) so common sense often needs dispensing with. It's a pain in the backside, granted but it is intended to stop you from having much bigger issues later on. Appreciate that's not a "fix" but hopefully it explains why you're in the bind you are. My advice would be to purchase a cheap mono laser, especially if your printing it primarily of black text type... It's cheaper and you don't have to worry about consumables you don't use. Martin
Posted on Jun 11, 2009
How do I override colour ink level to use as monochrome
can you go into the printer properties then preference's or the gear box change to grey scale printing only??. I can do that with my Cannon so saving on using the colour cartridge...hope this helps
Feb 07, 2012 | Minolta magicolor 7300 Laser Printer
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
My printer refuses to let me print when one ink color is gone
No, the CX9400 cannot be used if a cartridge is empty or missing and cannot be overridden.
Apr 08, 2010 | Epson Stylus CX9400 Photo Printer
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
Dec 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Hi-
Sep 01, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson CX8400 All-In-One InkJet Printer Logo
218 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
