Question about Hyundai W220D 22 inch LCD Monitor
Where can I purchase a new base... as the one that I dropped while moving got ran over by a truck... and I don't have enough fingers to hold all the pieces in place to glue same back together
  • 732 Answers
Chances are slim to none that you will be able to get new base for your unit. Better off trying to "fab" one from quarter-inch plexi-glass sheet and attaching with screws to back of unit.
12fixlouie
Posted on Sep 08, 2010
Wiper assembly appears to be working but wiper arms don't move
Try taking the blades of and holding the grooved assembly with your fingers or lightly with a pair of pliers.
The grooved assembly may be moving but not have enough power to move the wipers.
This I would then suggest to be a problem with the motor mechanism.
Regards Craig.
Jan 30, 2018 | Kia Sedona Cars & Trucks
Favorite thing dropped into the seat belt cavity in the back seat of a 2006 Lexus LS430. Any good ideas? Through the trunk or how do we remove the back seat?
Pop the rear seat base out. Just push against the seat base bottom on the sides of front of seat bottom with your knee and pull up with your fingers. Seat base will come up no problem. Retrieve your "favorite" thing and put the base back in, hold it down with your hands while pushing it towards the rear with your knee and it will pop over the holding clips. Ya got your piece back and no harm done.
Jul 20, 2017 | Lexus Cars & Trucks
Ran one load of laundry in washer, started another and the unit just beeps 3times and I push to reset but lid won't lock or start cycle. I tried moving dials to wake up machine but got no luck
My GE top loader has a little "finger" on the lid , when lid is closed it depress a switch inside a little hole , Now YOU with a wood pencil you turn machine on and press the little switch inside the hole, it may have dropped too low for the "plunger". the washer should start. now tighten the screws for that switch.
Jun 03, 2015 | Frigidaire FFLG1011MW Gas Washer/Dryer...
Question when u tighten. Your pressure. Plate are them fingers suppose to move in or supposed. To be out alittle
The "fingers" are you describe them, are what the release bearing presses on to remove the pressure from the clutch disc when you press the clutch pedal in. As you tighten the clutch disc, the fingers will move in. And with a new clutch disc, they will move in fairly far. As the clutch disc wears, the fingers will get higher and higher, eventually to the point of clutch slippage and thus needed replacement. So don't be too concerned if they seem to be almost flat....they still have enough room to release the clutch disc.
Apr 18, 2015 | Cars & Trucks
Okay i have a '89 ford f150 4x4 standard single cab short wheel base with a 302 & i just replaced the thermostat 180 degrees & replaced the fan clutch because thermostat stuck & fan clutch was bad & it ran...
Its possible that you got a faulty thermostat that is actually sticking open and not allowing the water to actually heat up to temperature. Try checking the heater and see if you actually have heat. If not, I would start there and purchase another thermostat. It's the cheapest route and I have purchased bad ones myself.
Aug 14, 2014 | Cars & Trucks
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
My husbands 97 chevy pick up with the vortex engine stalled while i was driving it the other day acted like it ran out of gas stalled 8 times in 4 miles but then would restart each time we replaced the...
, i had this problem on my truck had to get another fuel pump, which was oem, it pumps more gpm.
the injectors won't open if not enough pressure, sorry
Mar 15, 2011 | Chevrolet C1500 Cars & Trucks
Pump is not drive enough water to move the sweeper
If the pump ran dry at all and if you had air it very well may have you could have burnt the impeller or it may just be clogged, Remove the 6 bolts holding it together and pull apart, using pliers or vice grips hold the shaft and unscrew the impeller if it looks ok run a curved wire through the veins of the impeller. This should help. If the impeller is clogged their is something getting past the filter and you will need to fix that. Also. don't forget to check your finger screen.
May 13, 2009 | Pentair 3/4hp 115/230v Booster Pump -...
Idle Air Control acting up.....
check your EGR valve, make sure that it is not clogged and the valve can move smoothly
Feb 16, 2009 | 1995 Ford Explorer
Hyundai W220D 22 inch LCD Monitor Logo
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
