Question about KitchenAid KGST307 Gas Kitchen Range
Gas stovetop not igniting without matches
Hi, I read a few of your replies to people's problems. I have a problem with my gas stovetop not igniting when the knob is in the "ignite" position. It just clicks, and it sounds like the click is coming from a different burner sometimes. What would you say is the best way to solve this problem? spark module or ignitor replacement?
  • 5,911 Answers
If the rest of the surface igniters are working, more than likely your spark module is working fine. (This is normal, by the way) I would suspect that you have a bad spark electrode at the burner in question, a bad burner switch, or bad wiring.
I found several part listings for the model number you posted this question under at repairclinic.com. You will need to provide a more complete model number in order to narrow your search to ensure you get the right part. You can find your model number on a nameplate around the oven door opening, or lower drawer opening (if equipped). Some manufacturers also place this information on the back of the range.
I hope this helps answer some of your questions. Please reply back to this posting if you need further troubleshooting guidance.
Posted on May 15, 2008
Gexl44 gas range, oven stopped working for no apparent reason, stovetop still works just fine, no gas smell
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 04, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven "bake" burner wont ignite on a gas oven.
Oven not Working or Oven not Heating
heatman101
Dec 27, 2010 | Whirlpool Ovens
Creda stovetop tries to light without gas on.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 28, 2010 | Creda Colonial 42352 23 in. Electric...
Igniter clicks, but gas will not flow.
if you don't smell gas (rotten eggs/sulphur), the gas is off or clogged. there are little pin-hole spouts for the gas to come out before it gets to the burner, and they get clogged easily by falling food/liquid. you have to take the stovetop off to get to them.
Jul 31, 2009 | Tappan TGF320 Gas Kitchen Range
Stovetop works but oven does not.
Most likely your problem is the glowplug aka oven igniter. Even though it comes on it must reach a certain temp for the gas to come on. Occaisionally the valve will be bad but 90% of the time it is the igniter. Part number is 74007498
May 29, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
One stovetop burner does not initiate igniter sparking.
Its most likely the igniter. It might just be dirty, but its easy to install a new one. They are attached by two screws and a single plug. I'd suggest turning the power off to the stove before plugging in a new one.
Feb 14, 2009 | Viking VGSC306-4B Gas Kitchen Range
Igniter does not go off after surface burner is lit
Hi I have experienced this problem myself, it seemed to happen after cleaning the stovetop and in the
process I got the igniter wet. So I pulled out my blowdryer gave the igniters 15 or 20 secs on hi and
presto problem solved
Todd @ beach
Nov 09, 2008 | Jenn-Air PRG3610 (NP) Gas Kitchen Range
Gas stove with electric starter
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 | Ovens
Ignition
When you turn the gas valve to High or Ignite position..do you hear or smell gas going into the gas burner? If yes, then look at the position of the igniter in respect to the gas burner to see if it generates a spark either with or without gas running.. .. if you have gas entering the gas burner.. and if you've used the Grill a lot.. the jets may be clogged and need cleaned to allow gas flow thru them.. if the jets from the burner are clogged in or near the igniter..it may not ignite easily untill you get lots of propane in the area.. Check the gas jets to make sure you have gas coming out and then check the igniter to make sure it generates a spark.. Hope that helps..
Aug 28, 2008 | Weber Genesis Silver B Grill
KitchenAid KGST307 Gas Kitchen Range Logo
273 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
