Question about GE Washing Machines
I have a GE washer machine model #wwa58500r (about 18 years old) that is leaking oil or oil fealing item, under the washer. What is it, how important is it to fix it (since it is so old) and how can I stop it from leaking? Thanks Email: rpicciola@peoplepc.com
  • GE Master
  • 3,740 Answers
The lower seal is leaking. Over time the seal hardens and does not perform as it once did. Although this link is not your exact model the transmission is exactly the same. The seal that is leaking is item 756.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230798&diagram_id=20372026#d20372026
Close up view of seal
http://www.appliancepartspros.com/part_details.aspx?part_id=2045443
It is not a difficult task to change the seal. The hardes part is getting the old seal out that involves punching thru the old seal and prying it out after removing the drive pulley. Use a block of wood to gently tap the new seal in place.
Thanks for choosing FixYa.
Kelly
Posted on Sep 07, 2010
Washer leaks every time it drains, it agitates with no problem
Most likely the pump is leaking but you can't pinpoint the source without removing the cabinet. Pumps are a common failure item especially after you have some appliance years on the machine
Dec 17, 2013 | GE Profile WPRE6100G Top Load Washer
Brown oil is leaking from the bottom of the washer
The only place oil can come from is the transmission. If you do not have a big leak, it may run a long time (read: maybe a year or more) before low oil level in the transmission causes major appliance damage, but it's time to start looking for a new washer. Many washers these days do not even use an oil filled transmission. Current GE machines do not, and the Whirlpool models comming soon don't either. If you can afford it, the front loading LG washers (which are direct drive, thus no transmission or clutch, and have a 10 year motor warranty) are the best, in my opinion.
Jun 05, 2010 | GE Washing Machines
Hi! GE top load washer model number wwse5240 is leaving grease stains inside the machine after laundering and of course on clothes. Not sure how old this machine is.
Your transmission is leaking oil. It's probably 10 to 15 years old for the transmission to be leaking. It can be replaced but it's not a small job. Part 320 in this diagram is your transmission. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5224109&diagram_id=22255027#d22255027
Jan 30, 2010 | GE WDSR2080D Top Load Washer
Washer transmission oil leak?
they do contain oil
it would be best to run it till it dies
the tranny woont get any worse than it is
and eventually you will have to replace it
Oct 04, 2009 | Washing Machines
Grease Leak
Unfortunately not. In addition to replqacing the blet, the transmission must be replaced. It is the only item in your washing machine that contains gear oil. It's a tough job for the do-it-yourselfer...If I can help further, I am here.
Eric Campion
Mar 03, 2009 | GE WBSE2090A Top Load Washer
My washer is leaking grease or oil on the floor under the machine
Hello and welcome
You said, My GE washer is leaking a tan colored oil underneath the unit. I suspect it's the gear case leaking. How difficult is it to replace the gasket or seal. I like to fix things and have tools. If the gear oil is leaking this usually means the transmission is shot and on it's way out. It is not cost efficient to have it replaced. 99.9 % of the time you throw it out and buy a new washer.
For the cost of the Transmission and the labor.
you can buy a new washer.
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Feb 09, 2009 | GE WBSE2090A Top Load Washer
Oil on floor under washer
Oil is generally not a good sign. It means that the tranny seal is blown OR it means that the tub seal is bad which allows water to enter the tranny (water is heavier than oil... if water gets into the tranny it will displace the oil and force the oil out)
This being a GE? I'd wager that a tranny job is in order. If the machine is less than 5 years old it's under warranty so you'd call GE at 1-800-GE CARES. If it's more than 5 years old? Your washer is no more than a boat anchor. Get a new washer, preferably a Whirlpool. The repair cost for a new tranny will out-weigh the value of the machine.
Hope this helps.
Mar 23, 2008 | Kenmore 22642 Top Load Washer
Grease/oil under washer
Hi, there. Get some one to fix that leak ASAP. The lack of oil will ruin your machine's transmission and/or motor. If you've noticed that your machine runs louder than it used to, then ***stop using it*** until you get the leak repaired. I kept using mine and when it stopped working I couldn't get the parts (a transmission) so I have to get a new one.
Nov 30, 2006 | GE WDSR2080D Top Load Washer
Washing Machines Logo
44 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
