Question about Cycling
My ZStar 49CC ATV Quad will no longer start. The fuel line is fine, the engine suddenly died and wont start back up. The Fuel line had a minor leak but the Quad was working fine yesterday. Today, I added more fuel, ran and rode it for a bit. I let my friend get on so it was idling for about 10 seconds then the engine died out and wont start back up
  • 82 Answers
SOURCE: 49cc 2 stroke runs for 20 sec. then cuts out
20 seconds is all that is required to drain the float bowl. You have a float bowl/needle valve problem.
Posted on Apr 29, 2009
  • 1118 Answers
SOURCE: engine sputtered, then died. Towed home. I
Might be fuel pump, or filter is pluged up, best to chg. filter and then do a fuel pressure test.
Posted on May 03, 2009
redbeard00
  • 957 Answers
SOURCE: I have a craftsman 25 cc string trimmer with fuel
You shouldn't notice a difference if you remove the air filter. So I would replace it. Also if you are using compressed air to clean or blow-out the carb. Be careful, its not recommended and could make it worse.
Posted on May 14, 2009
SOURCE: Engine dies after quad is warmed up (10-15 minutes)
Just a hunch, had this happen to a bike of mine years ago, could be the piston rings are gettting ready to go(wore down). What happens is when the quad is cold the rings expand tight into the cylinder walls allowing it to get full compression and run ok. When it heats up they shrink allowing the slightest amount of give which in turn will cause you problems similar to what your describing.
Posted on Jun 10, 2009
mrrichardlbo
  • 59 Answers
SOURCE: gio mini quad 49cc no governer won't idle up
change the CDI unite it in the battery case.( price around 35 to 80 bucks )
Posted on Aug 16, 2009
Testimonial: "Thanks alot!"
How do I fix my 49cc 2 stroke pocket quad it has
If you have replaced the spark plug then the possibilities are the ignition coil is weak or the starter mechanism is faulty.
See this site for details of parts.
Mini Atv Quad Parts 47cc 49cc Stock Replacement
Sep 15, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Engine wont start on mini quadard 49cc model atv-2
A lot of guys are having trouble with that. If you have spark. disassemble the carb and clean it. then screw the set screw all the way in and back it out 1 1/4 turns. if you need more you do it in 1/4 turn increments.
Dec 24, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
Mini quadard 49cc model atv-2 pull start problem
a lot of guys are having issues with these machines. Most I believe are due to the carb settings. Turn the set screw all the way in and back it out 1 1/4 turns. Try that. if you need more you do it in 1/4 turn increments
My 49cc wont fire over
My 49cc 2 stroke pull start scooter wont turn over
Aug 19, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
Wheres the choke on a 49cc pocket rocket
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
Feb 02, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have an 49cc ATV midi quad bike and it will not start at all. Have changed the flywheel and pull cord and carb, but still have no joy. Have used easy start too! please help, had it over a year never bin...
I had this same problem. I had a very hard time to start this quad untill i was told to make sure the fuel filter is half full with gas. Which it wasnt getting gas through the filter. So i went down to our local dealer and purchased another filter. The new filter was getting gas this time but the quad still did not start. So i was told to take the throttle cable off the engine and pur gas right in the hole, but the cable back on, Put the choke on full make sure the gas valve is turned on and fire it up. it started right away. But i had to repeat this a few times. But works now
Ed
Jan 09, 2011 | Razor Dirt Quad Bike
Polaris 300 it will run get loud and die
2 strokes get loud before they run out of gas. check your fuel lines and carb to see if your getting enough fuel to the engine.
Dec 17, 2009 | Polaris ATV
2 stroke 49cc quad engine dies when i accelerate
well it is 2 stroke so if its rev'in slow thats not dunna help . my sister had one and its the kind of thing that u don't let it idle just keep it going. thats what i found best
Nov 01, 2009 | Razor Dirt Quad Bike
Pocket bike prblems
Get some engine starting fluid and spray a small amount in the air intake. If that doesn't work take out the spark plug and see if it sparks when you pull the cord and make sure it is not fouled. If it is wet with fuel dry out the plug and pull the cord a few times to clear the cylinder. Fresh premium fuel always works best on temperamental engines.
Sep 06, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
49cc kids ATV trouble shooting
in order to tighten your chain you can take a link off which would involve using a grinder, if you dont have one than go to an atv store and ask them to do it. theres a clip on the chain which holds it togther, remove the clip without damaging it than just pop the link off. that will take the chain off. i dont know what type off atv you have so there are probably bolts that hold pull the back end to tighten the chain look for those and if you can find them than tighten them.
for your engine do an oil change and drain out the carborator. if you need more help let me know.
Jun 24, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Cycling Logo
218 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
