Question about Belkin Wireless Share Router (F7D3302)
My router works for my PC, but not my laptop or Wii. When i go to change the settings, it takes me to a router shopping site instead. i need to get on wifi with my wii
    Sergeant:
  • 358 Answers
Configure your Wireless connection
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Posted on Nov 01, 2010
I can't get connected to Netflix.All that pops up is error code 209826
Error code 209826. Is this with a Wii? Error code references "Problem connecting to the Wii Shop channel. Either a problem with the router or the Wii Shop may be temporarily
down. Try again later."
I recommend turning off the Wii completely. Check the wireless router and unplug the router, but do not disconnect the cable. Keep powered off for 5 minutes. Plug router back in, let all the lights power up and then turn the Wii on and attempt to connect again. Should the issue continue, you may need to go through the Wii network set up and verify that it is communicating with the router.
Dec 30, 2014 | Netflix
Tip
Nintendo Wii Error Code 51031 This error code means that the wireless network...
<span>Nintendo Wii Error Code 51031</span><br /><br /><span>This error code means that the wireless network within range is not configured or is not compatible with your Nintendo Wii.</span><br /><br />-Make sure the router you are using is compatible. You can see a list of compatible routers by clicking <a href="http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp">here</a><br /><br />-Make sure the SSID(network name) you enter into the Wii settings matches the SSID of your router. This includes making sure capitalization, spaces, or special characters match exactly.<br /><br />You can log in to your router by going to the gateway address of the router(usually 192.168.1.1 and type this into your internet browser), and going into the wireless settings section. Check what the SSID is. This is what you should set on the WII.<br /><br />You can view my tech article on connecting and changing Wii network settings by clicking <a href="http://www.fixya.com/support/r9198848-connect_nintendo_wii_internet">here</a><br /><br />-In your home network, your router may not be assigning an IP address to your Wii console. Power cycle the equipment. Turn off all devices(modem, router and Wii). After 10 seconds turn on the modem, after 30 seconds turn on the router and after 30 seconds turn on the Wii. Try to connect online.<br /><br />If you are not using DCHP but instead have your home network setup to assign a IP address manually, you will need to setup the Wii with the IP/DNS addresses. You can set your manual settings in the Wii network settings menu. See the link above to my tech article.<br /><br />-Your router firmware may need to be upgraded. Visit your router manufacturers website and see if any updates are available.<br /><br />If after all the above steps you are still having trouble, you may want to reach out to Nintendo Technical Support at 800-255-3700<br /><br />I hope this article was informative!<br /><br />-G33k<br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /><span style="font-weight: bold;">Nintendo Wii Error Code 51031, Error Code 51031, Wii 51031</span>
on May 25, 2011 | Nintendo Wii Console
Getting error code 209552 on my wii
Sometimes wireless interference happens. They recommend changing your wireless router's channel to 1 or 11 instead of typically 6. Also if you get this on Wii shop channel, it means that sometimes the shop channel is down temporarily.
Nov 11, 2011 | Nintendo Wii Console
The wii shopping channel wont open so i can download netflix
You may need to update your wii console in order for you to get to the wii shop. Try a system update from the system menu and then try again with the wii shop. I hope this helps!
Apr 27, 2011 | Nintendo Wii Console
CANT CONNECT TO CALL OF DUTY BLACK OPS ON THE WII KEEPS SAYING UNABLE TO CONNECT TO SERVER?
You can try to change the channel on your router to either 1 or 11. How you do this depends on your router model.
Also make sure your network settings are correct on the Wii by running a test or trying to connect to the Wii Shop channel. If these work Call of Duty should work as well.
Feb 27, 2011 | Linksys Wireless-G WRT54G Router
How to identify security type on my belkin wireless router relative to nintendo wii security type options
For nintendo wii , you can use the security WEP or WPA ( PSK ).
These 2 security types will works with WII. If you put WEP,then 10 digit number will be the security code.
To change the security on the wireless network, you will need to open the set up page of the router.
Once you change the security on the router, it is recommended that you will change the wireless network name SSID. after changing the wireless settings , you will need to connect to the new wireless network on all your wireless devices like laptop , wii.
Click Here for step by step instructions
Mar 05, 2010 | Belkin Computers & Internet
Error52230
This is a issue setting up the Wii wireless connection, usually to do with the Wii and the router. I had this issue hooking mine up a few years back, and I had to do a manual setup on it instead of the automated "search for access point" option.
It took a bit, and if you aren't technincally savvy it may take you longer, but in the end it work.
I won't post it here, instead I'll link you to Nintendo's support site, where they'll tell you how to do a manual setup on it (complete with pictures)
Click here for how to set it up manually
Here is info on the code itself
Note for me, the issue was solved by manual set-up. The router was blocking the Wii somehow, and manual set-up solved it.
Nov 14, 2009 | Nintendo Wii Console
My belkin router won;t connect to my laptop, wii, ds or dsi
Did all these devices use wireless? Or were they plugged into it?
The router may have reset itself so you might have to sign in to the router and setup the wireless again.
The PC that is hooked via ethernet, did it use the router wirelessly at all?
Try signing into the router and check the wireless security key settings etc. Reset it if you have to type in a new key and try testing the settings with one of your wireless devices to see if it works. Remember to have the device on the same key/index/channel and the same security type as is set on the router.
Apr 12, 2009 | Belkin Computers & Internet
No wifi connection for ds lite
Did you try to set up your Wi-fi connection settings or your not in a good Wi-fi connection zone.If that doesn't work mabey not made by or for nintendo.
Dec 26, 2008 | Nintendo DS Lite Console
Wii online
You need to download the internet channel from wii shopping channel hope this helps...
Jan 22, 2008 | Nintendo Wii Console
Belkin Wireless Share Router (F7D3302) Logo
96 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
