Question about Sevylor 48 in Inflatable River Tube
WHERE IS THE AIR NOZZLE TO FILL THE SEVYLOR FLYING MANTA RAY LOCATED
  • 433 Answers
All the Sevylor tubes have a valve that comes apart in to two pieces, remove the top and you can fill remove the hole thing releases the air. You need a 12 volts high volume low pressure pump with connectors, 20 bucks in Overtons. Fill it till it is stiff, put it in the water let the air cool down inside then hand fill it with the connector and human breath to stiff it up again.
Posted on Sep 07, 2010
Quad copter won't lift off ground
Maybe battery is not accepting charge. I would try using a new battery.
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Gas fill problem
the filler tube relies on an air bleed hose that runs from the top of the tank to where you place the filler nozzle. This allows air in the tank to bleed out as you are filling it. If this tube is blocked (pinched) then the air has to come out the filler tube past the nozzle and any fuel will cut the flow of at the nozzle.
Nov 15, 2013 | 2005 Ford Explorer XLT
Sevylor st5656 what air presure should be in it
The ST5656 is a low pressure hull, so shouldn't be inflated to more than 1 psi, or about as firm as a ripe grapefruit. If you leave it out in the sun you need to let some air out or the air inside will expand and it will blow up
Apr 04, 2013 | Stearns SEVYLOR Sit on Top Kayak U250
Raft repair
Sevylor sells a patch kit, as well as a spray that is kind of like a silicone that works well on pinholes. Go the website: http://www.sevylor.com/Spare-Parts-Kit-P1898C45.aspx - more parts under accessories on the site.
You wouldn't have a copy of the manual for your boat, would you? I can't seem to find one - even called Sevylor and I couldn't get one!
May 15, 2012 | Sevylor Fish Hunter 6 Person Inflatable...
98 ply breeze heater blows cold air, replcd water pump, radiator, thermostat, filled w/coolant, no leaks inside car, both h/c hoses are warm, bled coolant system, fans work. Would the heater core be...
Yep! Take the heater hoses loose from the engine(one at water pupm\\mp and other one at thermostat housing area usually). Then take your water hose at your house,with a common old pistol grip nozzle,and spray water back thru the heater hose you took off the water pump side and that will force it back thru the heater core and out the hose you took off the thermostat side.
If you want to see the junk that flies out of it,tie a white rag or old tee shirt onto the end of the hose.You'll be amazed what flies out of there.Reconnect your heater hoses and see how it does.
I always fill the hose full of water so when I reconnect them,they don't have any airlock problem. don-ohio (:^)
Nov 07, 2011 | 1998 Plymouth Breeze
Need Manual fo Sevylor 12V Trolling motor
The Sevylor electric motor does directly mount to any Sevylor and Intex boat with out the need for an additional mount.
Sep 29, 2011 | Sevylor SBM 12Volt Fishing Motor
Protruding tube
I sell on eBay and I just went there to check for you. There is a lot of them there-not sure if its what you need exactly. Put in ebay search sevylor tube. Hope this helps burdfrenzy
Oct 17, 2009 | Sevylor 48 in Inflatable River Tube
Sevylor motor mount instructions
I dont believe a motor will mount to it. Sorry!
Sep 30, 2009 | Sevylor 48 in Inflatable River Tube
When I go to fill up the gas tank the gas keeps cutting off at the pump handle and I have to slow the gas pump to a trickle in order to fill the tank.
The problem is that your gas tank "pushes back" like it's full even when it isn't and makes the fuel valve click off. Tom and Ray on Car Talk covered this in a 2007 show and I pasted some of their response below:
"RAY: This condition is probably caused by either a blockage in your gasoline vapor recovery lines or a bad refueling control valve.
TOM: Gasoline vaporizes. How do we know that? Well, when gasoline is spilled, you can smell it, right? What you're smelling is vaporized gasoline.
RAY: And in the old days, when you filled up your tank, all the air inside the tank -- the air filled with gasoline vapors -- came whooshing out through the filler hole or through a vent at the top of the gas tank.
TOM: But then people in places like Los Angeles realized they couldn't see the person standing next to them due to smog. And since gasoline vapors contribute to smog, car makers were forced to install devices to capture those vapors.
RAY: So now each car has a vapor recovery unit that collects the gasoline vapors from the tank and then, the next time the car is started, sends them to the engine, where they're combusted. Your vapor recovery system isn't working, Lottie. One possibility is that one of the rubber hoses is blocked or collapsed."
Sep 16, 2009 | 2007 Lincoln MKX AWD
Sevylor 48 in Inflatable River Tube Logo
162 people viewed this question
Top Sevylor Sport & Outdoor - Others Experts
Are you a Sevylor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
