Question about Brother XL-2600
Have a new Brother 1250 Embroidery / Sewing Machine. I have the tension on 3, my thread breaks often and I have broken 5 needles just this week. I have used different thread, rethreaded carefully but do not know whatelse to do. Could it be the tension setting? Also, the bobbin came out and cannot determine from the instruction book just how it is attached. Any pictures or help on this is also appreciated.
  • sqs1011 Sep 11, 2010
    Have you sewed on this machine? Is the needle breaking when you sew or when you embroider?
  • 161 Answers
The tension for embriodery should be very light. also, there are needles just for embroidery, which have a bigger eye so the thread goes though easier.
Posted on Sep 12, 2010
The needle threader on my embroidery machine is no longer working.
There's a possibility of it being related. I would need more information though.
Jan 26, 2014 | Brother SE-270D Computerized Sewing...
Upper thread keeps breaking on my Brother HE-1 embroidery machine, tried adjusting the tension and nothing seems to work
could be a dull or bent needle. Could also be a burr on your hook. Try changing the needle first. If it's a burr on the hook or the needle plate, you have to take it to a tech for maintenance
Sewing Tech
Oct 25, 2013 | Brother HE-1 Embroidery Machine
I have a Singer Quantum XL-100 Sewing/Embroidery machine that repeatedly and frequently breaks needles. In one 10-minute sewing session, it broke six needles. The tension at the top of the machine i
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Feb 01, 2013 | Sewing Machines
The tread is breaking while sewing with brother ls 2125
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Nov 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
The top thread keeps breaking. The thread pulls tight and breaks. I have removed a broken thread piece from the upper take-up lever, rethreaded (several times), cleaned out bobbin, moved thread spool on...
try a tension a 3 to 5 on the top tension
try changing to a needle or if it's a new needle make sure the flat side of the needle faces the back of the machine and pushed all the way up into the needle holder
make sure the needle & thread are correct for each other, if the needle is to thin or to heavy for the fabric it will not work
Aug 27, 2011 | Brother InnovIs QC1000 Electronic Sewing...
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Jun 05, 2010 | Brother CE5000 Computerized Sewing Machine
I am sewing leather, less than 5/8 or just about thick and my upper thread keeps breaking or coming out of needle. i am using a leather needle, which i changed, cleaned the race, adjusted tension, using 50...
What brand leather needles are you using? Keep machine out of Sun ok. All leather needs to be in cool or room temperature. try loosening bottom tension just alittle or top tension, I would start with bottom......I also use commercial polyester thread when doing tougher materials..
let me know
Nov 28, 2009 | Brother CS-8072 Computerized Sewing...
My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Brother XL-2600 Logo
93 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
