Question about E-Machines eMachines Desktop PC
My emachine froze up so i unplugged everything and then plugged it back in windows was not running so I clicked onF10 and selected run repair........ran for about 15 minutes the it said click on finish to restart.....said if it is not repaired it will not restart but likely rerun the repair function......i clicked on finish and it was thinking for a few seconds then locked up agains the lights on my d screen is black other than the bar that shows it is thinking and the green dots are frozen.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
Try to run it through safe mode and repair windows registry with reginout as it seems there is some internal corruption in windows registry.
Posted on Sep 11, 2010
How to fix 'no signal' when turn on PC?
it is something about your monitor not connecting well with pc, check graphics card
Mar 25, 2013 | E-Machines eMachines Desktop PC
I was copying information from my computer to my external hard drive. My brother went on the computer and froze it. my external seems to be stuck in the loop of copying. it does not get recongized on my...
If you're on a mac, then you should open disk utility to try to mount the drive manually. You can do this by selecting it on the left side of the window and clicking the mount button on the top of the window.
if you're on a pc, then try unplugging the drive from everything, and plugging everything back in. There are many manual and recovery utilities online
May 01, 2011 | Cavalry Storage CAUM3701T0-OTB USB 2.0...
I'm working on an Emachine desktop PC running Windows XP Media Cntr Ed 2005. It worked fine for 6 mnths, but recently it wont get past a POST. It runs the POST startup tasks and then stops at the...
sounds like the CMOS memory is currupt, or you got a virus that worked its bay to the BIOS. I would first try to unplug the computer open the case and find the cmos battery. It looks like a big watch battery. Pull it out and leave it out for a good minute or so, plug it back in, and see if you can't get into the BIOS. If you do not find the battery. there should be a little jumper near the corner of your mainboard the says "CMOS" next to it. pull that out and leave it out for a minute or two. then plug it back in. This will clear anything in the bios and set everything back to factory defaults.. (this does not erase anything on the hard drive, just the options and memory in the BIOS)
Mar 10, 2011 | E-Machines eMachines Desktop PC
Emachines T 5088. Work very slowly
That machine comes with only 512 MB of RAM so it's going to be slow. The best way to speed it up is to upgrade the RAM.
There are some things you can do which will help.
1) Make sure you are virus free.
2) Run CCleaner . Both the main CLEANER (Analyze and then Run Cleaner) as well as the Registry (Scan for Issues and then Fix Selected Issues).
3) Run msconfig in the run box or the search box it will open a window click on the startup tab and deselect the one's which you dont require while system boots. Be very careful and only eliminate the non-essential programs. Everything you can eliminate here will free up resources.
Good luck
Jan 14, 2011 | E-Machines eMachines Desktop PC
Cant read a folder in a hdd transcend storejet 2.5 110gb
Looks like you probably have some corruption on that disk. Assuming it isn't physical damage on the disc, running a CHKDSK on that entire drive may fix that for you.
With the drive plugged in, open My Computer, right-click on the drive and select PROPERTIES. Then click on the TOOLS tab, click CHECK NOW, check both boxes then click START. Let than run and it will tell you when it is done. Once it is, try opening that folder again.
Jan 21, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I have a document that will not cancel or print
Depending on the operating system - go to services, which can be accessed from computer management OR just by typing services.msc in the run.. command. Once you have the services interface open - find print spooler services - right click and select stop to stop the service. Check to see if that document still shows - most likely you will not be able to see as printer interface will not open. Now right click print spooler service and selct start to start the service. Check - most likely doucment would disappear.
Mar 18, 2009 | HP PSC 1210 All-In-One InkJet Printer
T3025 windows xp home, crashed on Tues - haven't been able to access internet since.
try to run in safe mode with F* key.
when switch the pc press F8 key thwn choose safe mode.
go tro satrt menu then run type there "chkdsk /r"
then press "y"
then restart the system.
that it
aslo try to run in last known good config...
Oct 03, 2008 | E-Machines eMachines Desktop PC
Sansa e260 problems : Music files freezes the sansa and restarts it.
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Dec 05, 2007 | SanDisk Sansa e260 MP3 Player
Emachines T1840, Computer will not get past start screen
I had the same problem, what i did is unplug it, wait for like 10 min, then plug in the wire and start it. It worked. Try it.
Sep 18, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
E-Machines eMachines Desktop PC Logo
22 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
