Question about Timex Expedition E Compass Watch Titanium T49201
Can i find instuctions to compass watch - Timex Expedition E Compass Watch Titanium T49201
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
First, assuming you do not have the manual, following the notes below, find an outdoors location away from any medal building, obstructions, etc. You must calibrate the compass to get anywhere near the +/- 10 degrees accuracy readings claimed.
Timex has two ways to find information about your particular watch. If you don't have the manual, Try this link:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Posted on Sep 08, 2010
How do I get the compass working right
Sounds like there is a magnetic field interfering with your compass. Something close to the compass is deflecting the needle, so look for the source close to the compass location.
Jan 03, 2016 | Casio Watches
The compass on myTimex WS4 fails to calibrate. Have tried removing the battery and resetting everything but still no joy. Is the any other way to calculate the compass?
There is a process to make an all reset. After the reset try again. The user user manual can be downloaded from Timex. Make very sure the watch is absolutely flat and far from metal objects. Even being near most furniture can effect the reading because they can have metal springs. Many homes have a lot of metal in their construction. It's best to calibrate the compass out doors away from power wires or cars or anything metal. On the street you can have metal under the pavement.
If this does not work call Timex. There have been instances where the compass module or sensor had to be changed. I have the same watch. It's a very good one.
Sep 25, 2014 | Timex Expedition WS4 WideScreen 4...
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
How do you use the compass bezel on an armitron watch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals.Rate me, please
Mar 21, 2010 | Armitron Compass Bezel Chronograph Sport...
How to set the compass on a casio SGW 100
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Casio Digital Compass Twin Sensor Sport...
I have a Timex e-tide with compass, temp and tide functions. The compass no longer points north and will randomly point in any direct when activated, is there a way to re-calibrate the compass?
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 13, 2010 | Timex Expedition Adventure Tech Compass...
Throw it in the bin, find any old analogue watch, set the right time and point the hour hand at the sun. Bisect the angle between the hour hand and the 12-o-clock position on your watch and that line points due south - if you're in the northern hemisphere - or due north if you're an Australian. For night navigation, find the Pole star, just up from the 'big dipper', then off you go...
Sep 11, 2009 | Timex Expedition Digital Compass T40611...
Compass is no longer pointing North
I had the same issue. I found that if you re-calibrate the compass the same way you did the first time, then it will act properly. I've had to do this a couple of times and it works.
Jun 12, 2009 | Timex Expedition E Compass Watch Titanium...
Compass dial turned opposite direction
you might be able to reverse the poles back to normal with a magnet but be careful not to scratch face or get it closer than you need to to the insides of the watch.
Sep 26, 2008 | Field and Stream F25SLUMI Wrist Watch
Timex Expedition E Compass Watch Titanium T49201 Logo
393 people viewed this question
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
