Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
WATER DOES NOT COMPLETLY DRAIN - Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 08, 2010
My dishwasher does not drain completly. there is water at the bottom of the dishwasher.
heatman101
Mar 31, 2011 | Tappan Dishwashers
The screen on my washer is saying the code LD i dont have a manual and it wont drain completly. I took my clothes out and they were completly soaked with water. HELP! :D
The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem
Jan 12, 2011 | Kenmore 22062 Top Load Washer
Washing machine won't spin in the spin cycle. The model # is GWL11US the serial # is EYN654081 I tried to get the date of purchase and couldn't ascertain that info. CAN YOU HELP!
check that ALL of the water has been pumped out you could have a partally blocked drain pump causing the water level pressure switch not to be satisfied that the tub is completly drained. If tub is NOT completly drained it wont spin but it will usually give you an error code try drain spin to see if that works draining it a second time
Feb 12, 2010 | Fisher and Paykel Washing Machines
The washer fills with water when not in use.
this is probably the water valve . not shutting of completly . replace it .. mm
Dec 05, 2009 | Washing Machines
Water dripping in to freezer bottom ten pools on
Sounds like you have a drain that is plugged. When it goes into defrost the water hass no place to run. Thats when you get water like that. I would defrost it completly. Then try to get to the drain and pour hot water slowly to see if it goes all the way down to the pan. If not. Yu may have to have air pressure to go thru the drain.
Aug 30, 2009 | Refrigerators
My GE Profile doesn"t drain completly, leaving about 2" of water.
Sounds like a water level sensor is on the fritz. The drain valve is probably opening if the level drops at all.
Jul 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Whirlpool compact washer won't drain
check the pump, usually has an item that is lodged into the impellers
Feb 16, 2009 | Whirlpool Laundry 22'' 2.1 Cu. Ft....
Water won't drain completly
Start by cleaning the drain hose. this is a common issue when food builds up in the drain hose. most of the time it is what is called the air gap. the little metal looking thing on your sink. take the cap off and then there is another small cap underneath usually white that you would push 2 tabs in to get it out and you would see any debris inside.
Nov 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
93 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
