Question about Acer Computers & Internet
Acer P5Q-EM mobo. When trying to boot i get this message USB DEVICE OVER CURRENT STATUS DETECTED WILL SWHUT DOWN IN 15 sec. which it does, I am also unable to get into the bios, even before I get the closing down message. Answer to the problem will be appreciated. Thank you. Ray Angell
  • 22 Answers
Ive seen this a few times. Its either a usb device plugged into the board shorting a usb port out, or whoever put it together wired the usb ports wrong on the board. FYI its an Asus mb not an Acer.
Posted on Sep 07, 2010
Won't boot properly
Sounds like you plugged some device in that caused a sudden surge in current draw. Did you plug in a USB device that maybe went in awkwardly? If so that may be your problem.
Mar 04, 2014 | ASUS A88X-PRO - motherboard
When I go to boot up I get a message saying " USB DEVICE OVER CURRENT STATUS DETECTED CLOSE DOWN IN 15 SECs" is my motherboard now faulty?
Maybe but there are a few things to check before you call the Asus,
Check all of your USB ports and make sure that there is noting connected, stuck, broken, sticking out, sticking in, or falling out.
If you have front and back USB ports that is connected by cables to your motherboard disconnect them.
If issue still occurs then you have a damaged USB port on your motherboard, Call Asus for further instructions.
Dec 20, 2012 | ASUS M2N-MX Motherboard
Current status overload detected
Revert to Windows 7 .. Windows 8 is too 'new' to have all the bugs (and drivers) sorted out ...
Nov 12, 2012 | ASUS LGA 1155 - P67 - SATA 6Gbps and USB...
Recurring issue: KGPE-D16 opteron 2-CPU "USB
If its forcing a shutdown of the entire machine, I think it may be protecting itself from a voltage issue. What do you have plugged into your USB ports? It sounds like it has detected a voltage problem coming from one of the devices connected to one of its USB ports or something near it and to ensure that the motherboard doesn't get fried its shutting the computer down.
The message is telling you that its detected a device that is over the allowable amount of electrical current and is protecting itself from electrical failure. It could be a problem with the USB jumpers on the motherboard that connect the front usb ports. You might try unplugging these connectors and try to boot up the machine. Leave them unplugged and boot up the machine, if you still get the error after that, it may be a grounding issue with the motherboard mounts that anchor the motherboard to your computer case. If you have any extra mounts underneath the board that you aren't actually using but are coming in contact with the board, you may have to remove them, which would probably involve removing the motherboard from the case.
Feb 13, 2011 | ASUS KGPED16 AMD Opteron Server Bd
USB Over Current Status Detected, Computer will shut down in 15 seconds
this message popped up because one of the device which you connected to the usb of the pc was overdrawing current i.e more than 5V DC. Hence, the built in system security gave this message and will shut down your computer in 15 seconds. In order to avoid this message first remove all the usb items connected to it and then connect one by one and detect the faulty one and replace.
Jan 29, 2011 | ASUS P5PE-VM Motherboard
When the computer is booting these words appears usb device over current status detected, and then after 15 seconds the computer is shut down
A USB device is drawing too much power so the system crashes. Remove all devices attached to USB and try again. If it's the same then remove all external USB ports - the ones connected with wires to the motherboard. If it's the same then there's a short in the motherboard - unfixable, replace it with a new one.
Jul 10, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
160 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
