Question about GE WHRE5260E Top Load Washer
Leaking from the front
I have the ge whre5260e waher and it's leaking under the front of the washer.Possible causes?? The washer was in storage for a few months then moved and now leaks????
  • 481 Answers
Take a butter knife and release the two clips on the top of the front panel (look in the seem between the top and front panel and push the butter knife directly into the clips), this will release the front panel from the machine. then you can see where the water is coming from.
Posted on Jun 27, 2008
Ge WASHER WHRE5260E shakes violently and makes loud noises during spin cycle
the cloths in the washer needs to be ballance... too much load on one side
Nov 14, 2010 | GE WHRE5260E Top Load Washer
My GE WHRE5260E leaks out the bottom occasionally ,what is the problem
check the seal on your drain pump it is where it attaches to the motor
Feb 16, 2010 | GE WHRE5260E Top Load Washer
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Transmission noise
Washers normally don't have much grease in them at all....the transmission is full of oil....which on GE washers often gets dumped onto the floor.Remove power, tilt the washer back and check on/around/near the large center pulley under the tranny....often the belt and pulley throw the oil around inside the cabinet.
Some of the oils they use are a synthetic oil....acts a little diff than some other oils....sometimes if water gets into the tranny the oil can change foamy or black due to the moisture.
Feb 10, 2009 | GE WHRE5260E Top Load Washer
GE profile washer
Thanks for the questionOn a ge washer theres a over flow tube located at the back left side Sometimes if you use a high sudzing detergent , it could leak not to much to worry about just change detergent to a low sudzing one THanks for the question The appliance doc
Sep 03, 2008 | GE WHRE5260E Top Load Washer
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
Water leaking from bottam while in running cycle
water leaking from under the machine while running. Also will not stop filling in the rinse cycle.
Jun 14, 2008 | GE WHRE5260E Top Load Washer
Water leaking where motor goes into the drum
there is a tub seal under the spin tub that proab needs replacing open the front panel then raise the top then grab the agitator and **** up on it hard it should snap out then unsnap the splash ring around the outer tub take the little bolt out of the agitator drive loosen the nut on the spin tub and remove it keep going down till you get to the tub seal replace it then reassemble
May 22, 2008 | GE WHRE5260E Top Load Washer
GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Jan 23, 2008 | GE WHRE5260E Top Load Washer
GE WHRE5260E Top Load Washer Logo
114 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
