What size screw does Olevia tv uses for wall mount and what thread style?
  • 490 Answers
M4 or m6 x 20mm phillips head.
Posted on Sep 07, 2010
I have a Samsung UN32M530D smart TV that I want to mount on the wall. The 4 holes at the back of the TV are smooth and do not have threads for screws. How do I attach the TV to the wall mount?
Re: un65ks9000f upper wall mounting hole adapter It's not an adapter but rather a spacer. The issue is that the back of the TV is thinner at the to than at the botton. As a result, a mounting bracket cannot be screwed to the back without streessing the back panel. The spacers essentially move the mountin plane far enough back that a bracket can be screwed down without sressing the back plane.
Do NOT under any circunstances try to use the specified screws without the spaceers as the screws will be too long and will damage the set.
The official name for this piece is "Holder Wall Ring" which is probably a translation from some more meaningful Korean words.
You can buy them here http://www.samsungparts.com/Products/Parts_and_Accessories/PID-BN61-13518A.aspx?model=UN55KS8000FXZA
It is part number BN61-13518AThis item is the perfect compact size for the area I needed to use it in. It was hard to find something at an affordable price that would be the right size and good quality. The kit contains everything I could have possibly needed to assemble and use it.
Oct 31, 2017 | Samsung Televison & Video
Can my tv be wall mounted and is there a special kind of wall mount
Check Walmart , all types / sizes of Wall mounts available
Mar 16, 2015 | Televison & Video
Olevia 527-S12. I need to know the thread size for the 6 screws that go into the back of the TV for attachment to a wall mount. Thanks.
Metric screw either M4 or M5 for that you can get them from HD or Lowe's for about 50 cents each. The length will depend on how thick the mounting brackets are. When you buy wall mounting kit, it will come with these Metric screws already.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Apr 27, 2011 | Syntax Olevia 527-S11 Television
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
I need to know the size of screws i neddto wall mount my tv
First you need a tv wall bracket made for that tv's weight and size to have a safe tv on your wall. The tv must be secured properly or it might fall. So the screws would come with this mounting kit and if they didn't I would fined out were they are. You must mount to a strong structure, like a stud in the wall or a metal frame built for it. The screws that I would use if might mounting kit did not have them would be as big as they would fit in the mounting bracket holes and that all the mounting holes wear being used and long enough to not be pulled out and in the stud about 3/4 of the way through the stud. They would be a good metal screw with a washer and the right threads for what ever material you are mounting it to. Thanks
Oct 05, 2010 | Televison & Video
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Dec 17, 2009 | Olevia 332V LCD TV
I have a 37 inch olevia hd tv..It was mounted on the wall but now we want to put it back on the base and cannot find the screws to reattach the base to the tv. Can you tell me the size of the screws?
This is a difficult one as you have about 50sizes possible for this one. Try calling olevia and giving them the model # they might have that info but its pretty technical and more then likely you'll need to go to a Home depot and just pick up several fine threaded screws (about $.05-$.10each) and try em all to see which one fits. Its a pain but may be the only way. Make sure you don't get them too long as this will damage the threads or not tighten the mount. Try about 1" to 1-1/2" screws. depending on how thick the base plate is. you want about 3/4" of the screw inside the tv depending on how deep the threads (can stick a toothpick inside it to gauge how deep) so ad 3/4" to the thickness of the base plate.
Sep 12, 2009 | Televison & Video
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Televison & Video Logo
756 people viewed this question
Top Televison & Video Experts
