Question about Mr. Heater Natural Gas Garage Heater - 45,000 BTU
I'm looking for replacement parts such as the gas valve,manifold and circuit board. Where can I get them at a reasonable price or even used. It's a Mr. heater big maxx 45,000 BTU. Model number mhu45ng
  • Mr. Heater Master
  • 3,238 Answers
Try national energy they are on line
Posted on Sep 08, 2010
Will not select new stitches and needle stuck in one positioh?
Hi Nanette...the first thought I had is..if it's electonic circuitry, there's. a possibility that your circuit board or boards have a failed part. The reason I mention this..I own two Singer Athena 2000. These allowed different stitches that happen via electronic circuit boards. One of my Athena's will only stitch straight because the circuit board that controls stitch selection has failed. The other works fine. So..my first suggestion is to look for a circuit board replacement and depending on the cost and value to you...have it replaced or better yet, replace it yourself. Though, you could compare buying a used one like yours since, often times, electronic boards are expensive. Just look to see if the board is still available. at..and this is just an idea...www.sewingpartsonline.co/elna-sewing-machine-parts-model-list.aspx
If you decide to take it in for repair and you have a price knowledge of the part, you'll have a better idea if the price for repair with labor makes sense to you. Depending. on the model,also, your electronic. baord may be easily repaired as some boards look very simple with a few resistors and capacitors...the capacitors will fail withwith, but are cheap and easy to replace. Obviously..someone would need to look at your circuit. board and see if the parts are out of tolerances. A bulging capacitor is a sure sign that your board has failed and is lucky to stitch straight. Hope this helps you resolve this...I was lucky and I just found a used Athena for $25 on Craigslist that works...cheaper than having a refurbished. board installed. Best Wishes!
Oct 29, 2017 | Sewing Machines
Jennair cooktop gas
I would go online and look for repair parts from e replacement or similar type pages and byuy the valves there.Perhaps this is something left to repairman. Natural gas leak. may cause damage or *****.
Jan 14, 2018 | Cooktops
GAS TOP WORKS BUT OVEN DOES NOT
This problem is commonly attributed to a defective Electronic Oven Control (EOC), or also referred to as an Electronic Range Control (ERC) board. This is the clock/timer assembly. The ovens on these ranges are controlled by the EOC, and if the control board fails, the oven igniters will not function. You will still be able to use the surface burners, however, as they are controlled by individual electrodes via a spark module. The following link explains how to access and replace MOST control boards: http://www.fixya.com/support/r3727366-replacing_control_kitchen_range A less likely cause would be two bad igniters in the oven. Each manifold (Bake and Broil) uses a separate igniter). As the igniters age from repeated use, they can become weak and no longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in most ovens each use a glow bar or electrode type igniter with a gas safety valve to ignite. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If a SINGLE igniter is still working (i.e., the broiler still works), its more than likely not a control board issue, either.
NOTE: You CANNOT light the oven with a match because the manifold uses a safety valve that requires a certain current potential flowing through the igniter to open and allow gas flow. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. Such a condition could potentially create an explosion hazard.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
If you have any questions please post back and let me know. I hope this helps you.
Jul 26, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Bottom oven not working when you turn oven on no gas seems to be going in rest off cooker fine
This problem is commonly attributed to a bad igniter on the bake manifold in the bottom of the oven. As the igniters age from repeated use, they can become weak and no longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
The burner manifolds in most ovens each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If a single igniter is still working (i.e., the broiler still works), its more than likely not a control board issue, either.
NOTE: You cannot light the oven with a match because the manifold uses a safety valve that requires a certain current potential flowing through the igniter to open and allow gas flow. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. Such a condition could potentially create an explosion hazard.
repairclinic.com
If you have any questions please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 01, 2011 | Kitchen Ranges
OVEN WONT LIGHT BUT BURNERS AND BROILER DO. TAPPAN 30-3860-23/03
More than likely, you have a bad igniter on the bake manifold in the oven. As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. Since the broiler still works, its more than likely not a control board issue, either.
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. The part number for a replacement igniter for the model you have listed is 5303935066. The price is about $23. NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
Aug 12, 2010 | Tappan TGFS_63 Gas Kitchen Range
Oven does not light. Top ignitor glows red bottom
Since BOTH oven manifolds and surface burners are usually fed from the same source, this is probably the result of failed igniter(s) in the oven. This is assuming that your surface burners are working, or course. If you are trying to light the BAKE manifold, the broiler manifold is used on some model to speed up the pre-heat process. So, you may see the broiler attempt to light as well. If you have tried using only the broiler by itself and it still does not light, you may have a weak igniter on that manifold as well. Double check your symptoms.
If this is a GAS range, as these igniters age from repeated use, they can become weak and longer function. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. It can be a control board issue, but is usually a weak or failed oven igniter.
repairclinic.com
If you have any questions please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Jul 19, 2010 | Tappan TGF657 Gas Kitchen Range
Kenmore oven won't light
If the broiler still works and the surface burners light, you more than likely have a bad igniter on the bake manifold. The following link epxlains a little theory about these igniters and how to replace one:
The broiler and bake manifolds have separate igniters, but share a common regulator and safety valve. So, if the broiler works, you don't have a gas problem. The surface igniters use electrodes to ignite gas which are fed from a spark module. So, some deductive reasoning can easily determine what the likely problem is.
Replacement parts can be purchased at any of the following websites:
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites also include helpful exploded view diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Mar 05, 2010 | Hotpoint RGB745 Gas Kitchen Range
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Open Questions:
See all Mr. Heater Natural Gas Garage Heater - 45,000 BTU Questions
Mr. Heater Natural Gas Garage Heater - 45,000 BTU Logo
526 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
