Question about EliteGroup ECS Motherboard MB K7VTA3 Socket A AMD XP DURON SEMPRON (796791550175)
Mo bo K7VTA 3 vers2 will not properly identify 1.4 Athlon chip - sees it as 900 Athlon. Ditto for 1800 XP - comes out as a 1.15. Using PC2700 DDR in lieu of PC2100. Can that be the problem?
  • 79 Answers
Hi
this is the answer of your problem i give you this complete link and you can find the download bottom
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=331&DetailName=Feature&MenuID=24&LanID=9
regard fdlixboy
Posted on Sep 07, 2010
  • 62 Answers
Set FSB frequency from 100 to 133 and your CPU should be working at correct speed. The settings that you should apply are:
  • JP2: short pins 2-3,
  • JP3: short pins 1-2.
Jumpers are located near CMOS battery.
If this is the solution for your problem, please rate my post.
Regards,
No signal going to monitor
1-Check out your video card to make sure it is properly seated in mo bo. 2- If video is from on board chip then add a video card to see if that works - if so your mo bo video is done.
Sep 15, 2017 | The Computers & Internet
How do you know when a memory stick is single-bank? I want to upgrade my A7V8X-X with 3 Gs, but I keep getting confuse how to determent what is single-bank! Is there a specific code in the product...
This is the memory spec for your motherboard...
3 x DDR DIMM Sockets
Max. 3 GB unbuffered PC2100 / PC1600 non-ECC SDRAM Memory (PC3200 Max. to 2 banks only / PC2700 Max to 4 banks only)
Part of the memory spec will tell you if it is single sided (memory chips only on one side of board)
Double sided is memory chips on both sides of the board....Some systems will not work with double sided memory...
Feb 10, 2011 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
Mother board ASUS A7s333 with 3 slots for RAM.
change your ram's one of them is mismatched
change from where u have bought it....
it will work
helpful i'll always here.....
Oct 23, 2009 | ASUS A7S333 Motherboard
Two 1GB 400MHz RAM's or two 1GB 333MHz RAM's??
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot
So, yes, you can put two 400MHz modules in the slots.
Jul 05, 2009 | MSI 915GLM-V Motherboard
I want to add more ram in my pc km400/km266
Oddly enough this board has the following specs: The board supports both Althon and Duron processors up to Athlon XP 2800+ (3000+ with a BIOS update). It can handle 3 GB of DDR333 RAM (or 2 GB of DDR400, but not all types are supported).
That's the older 184pin DDR ram in PC2700 or PC3200 guises. I can see no reason why it would only accept 2gb of the faster Ram.
Why not go over to www.crucial.com  and run the online scan to get the true story on your board?
Jan 05, 2009 | AMD Via KT400 Athlon(XP)/Duron SktA DDR...
GA-7N400-L
Bartie,
First we need to properly identify your processor. You can go to AMD's website and under their Support and downloads page download a utility that can properly Identify your CPU Through codes it can read off of your chip.
If it is an Athlon 2800 this tool will tell you so. (Then it is likely your BIOS on the Motherboard just isn't recogniing it properly)
If it is an Athlon 2600 (Which I think is the more likely one) You may have purchased your Athlon from a less than reputable dealer. Who either remarked the chip themself or purchased it from a remarker at a discounted rate.
OK so now your wondering what is "Remarking" . This is when a chip dealer aquires a large amount of lower end chips then modify it by jumping some leads on the chip making it run beyond its intended rate (A process called OVERCLOCKING) and then prints a higher end processors stamp on it allowing them to sell it at a higher cost.
I hope this helps you
Dave
Nov 15, 2008 | Gigabyte GA-7N400-L Motherboard
Asrock K7S41GX "NEW" does not work :bip-bip-bip
3 beeps is a memory error. remove the memory and put it in the first slot.
also the memory replacement calls for ddr pc2700.
Robert
Sep 05, 2008 | Asrock K7S41GX Motherboard
Increasing Memory Ram
According to the memory configurator at www.crucial.com your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
Look here for more information.
http://www.crucial.com/store/listparts.aspx?model=MS-6390
Aug 28, 2008 | Intel Motherboard
Amd sempron 2800+
i want AMD Sempron(tm) processor 2800+ free downloads driver
May 27, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Memory slots DiMM A1&A2 does not work
Fixed the memory well and and insert the memory one by one.
first insert 1 memory and test, and then so on.
If not work work clean the slot and also the memory.
Jan 08, 2008 | ASUS A8N-E Motherboard
EliteGroup ECS Motherboard MB K7VTA3 Socket A AMD XP DURON SEMPRON (796791550175) Logo
117 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
