Question about Yamaha Audio Players & Recorders
Yamaha RX-V730 amp. When the on/standby switch is pressed the display lights up for about one second and then switches off. What's the problem?
  • peterwil Sep 07, 2010
    Did not solve the problem. I guess I need to take it to a repair shop, unless you have any other suggestions.
    At least I know it's not a simple fix.
  • 10,594 Answers
Receiver turns Off due to protection circuit activation that detects some problem.
Unplug receiver from wall socket and remove speaker wires from connectors at back of unit, replug receiver back in and turn it On.
If it remains On that means any speaker or its connecting wire have problem, check each speaker connecting with receiver one-by-one to find out defective one.
and if receiver still wont power up than it got problem in amplifier output section that needs visual check by local tv repair shop guy as it is hardware problem and damaged parts will be replaced.
Let me know if you have additional question.
Thanks.
Posted on Sep 07, 2010
  • Shahid Electronics
    Shahid Electronics Sep 07, 2010
    I gave you user level suggestions to fix the issue but it sounds that receiver got problem in amplifier output section as mentioned before and local tv repair shop trip is due to care of it.
    Thanks.
Can I download the speaker wiring instructions for surround sound, lost mine
try here : https://www.manualowl.com/p/Yamaha/RX-V730/Manual/87206
Dec 20, 2015 | Yamaha RX-V730 Receiver
How to power up av receiver
Connect the AC power chord provided with the Receiver and switch-on power - the standby indicator glows now press the standby switch to power on your receiver
Jun 20, 2015 | Yamaha RX-A1020
How can I reset all settings on my yamaha rx-v730 to factory default?
Use Advanced Setup mode - see the manual. From standby press both STANDBY + STRAIGHT buttons, then choose INIT / ALL.
Oct 05, 2009 | Yamaha RX-V730 Receiver
Yamaha Rx-v730 - only hear "click" when try to turn it on
That may due to a bad power transistor, huge current flows when it's powered up, protection circuit kicks in and switch off the unit. Get to repair shop for check up and replacement.
Mar 07, 2009 | Yamaha RX-V730 Receiver
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
Jun 28, 2017 | Yamaha Audio Players & Recorders
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Unit powers up for about two seconds and then dies.
Are all the speakers connected?
Most A/V amps will go into standby if the speakers arent detected
Dec 15, 2007 | Yamaha RX-V730 Receiver
270 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
