Question about Refrigerators
I have a Sub Zero refrigerator/freezer, Mod # 550, Ser # p1100552. My problem is the ice maker control arm pops out of its socket when the freezer compartment is closed. The ice continues to be made or no ice is made. The control arm part # is 4202730
  • tamurtl Sep 07, 2010
    There is no problem getting water to the ice maker. It is the the ice level control arm that is the problem . Please reread my posted problem.
    I think you are getting closer to understanding my problem. In this ice maker the plastic lever is a combination heavy wire that inserts into the front and back of the ice maker and the plastic part snaps into the wire. the problem is that when the freezer drawer is closed the wire/plastic lever is pushed out from it front socket which I think is the water control on/off switch. Why is this happening and what can be done to stop it from happening
    Genius:
  • 1,478 Answers
An ice maker, as you all know is an appliance in your refrigerator's freezer that makes ice cubes. The ice maker receives water through a quarter inch pipe placed behind the refrigerator, which in turn is connected to the water pipe and tap valve. As and when water is needed, the valve lets the water flow through a fill tube into the ice maker assembly and thus, the water gets frozen into ice cubes. A thermostat is attached to the ice maker to monitor the temperature. Once the ice is ready, the ice cubes are pushed by the ejector blades into a bin till it is full. Now that you are aware about the functioning of an ice maker, you need to identify the ice maker problems that might be causing trouble.
With your ice maker not working properly, you might be wondering the reason behind the malfunctioning of your ice maker. Several factors could be involved in case your ice maker is not making any ice at all. It might be caused due to a defect in the water supply line. It could be possible that the water valve isn't getting any water. Check the water line at the back of the freezer for any blockage. Look for the water shut-off valve placed behind the refrigerator or under the sink and turn it off.
Next step would be to unscrew the copper line located at the back of the refrigerator. Now place the copper line in a bucket and turn on the valve to check if pressurized water comes out. The problem could also be linked to a defective tap valve. You could have it replaced. Since, freezer temperature can also be responsible for ice maker malfunctioning, make sure the freezer is not too warm.
Take care.
Posted on Sep 07, 2010
  • Jimoh Adeleke Muyideen Sep 07, 2010
    If your ice maker is not producing any ice at all, it could be due to
    various reasons. Firstly, check the right side of ice maker for a wire.
    The wire will be in an erected position, if the machine is turned off.
    In such a case, lower the plastic lever present in there or the wire
    directly if there is no plastic lever. This should be enough for your
    ice maker to start functioning once again.
    President:
  • 1,796 Answers
Hi!!
The Ice Level Arm has two plastic inserts, one on each side, make sure the inserts are in place. If not, that is the reason why the Arm keeps falling off. Click on the link below for a picture of the Ice Level Arm and the inserts.
Good Luck! Don't forget to rate this post!!
Posted on Sep 08, 2010
My sub-zero 680 fill arm on the ice maker will not lower. As a result the ice maker will not come on because the arm remains in the raised position. How can I get it to lower? I've tried turning off the...
Get a new ice maker. Nothing in the ice box controls the whims of that ice maker. Only it can dictate whether or not it wants to work correct.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 18, 2011 | Sub-Zero 680 / S
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
The ice maker in my 550 bottom drawer makes ice but does not shut off before spilling a few ice cubes into the drawer. In lookin at teh metal arm that exrendes into the tray it appears that it may not...
good day,
Sub Zero makes both a wire device and on some models a round rubber device that slides over the ice level arm. If you don't have one on your model, call your local appliance parts house and check with them. The wire model just clips on, the rubber style has a **** in it. The purpose is to shut the ice maker off before it becomes too full, causing your problem.
Nov 22, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
My subzero 550 ice maker is not making ice
My subzero model 550 is not making ice after I shut the water off for a plumbing repair. Now that I turned water back on my icemaker is not working.
Jan 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
My Sub-Zero drain ices up too!
There is a drain tube heater and a floor pan heater kit for this model from Subzero
This is Not for a DIY project
Affordable Appliance Repair
Lake Forest, CA.92630
Aug 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Refrigerators Logo
168 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
