Question about Liebherr Refrigerators
My fridge leaks water from underneath the lower front panel on the left. It leaks half cupful about every other day.
  • kmq1986 Sep 08, 2010
    Thanks Oxbow for your reply. We have a constant stream of water slowly filling our vegetable drawer also. This is above the freezer and ice compartments.
  • 503 Answers
If this is a model with the freezer on top your drain is plugged. Drain from the Fridge section exits the back just below the level of the fridge. At the bottom of the drain line is a loop for an air trap which could be plugged. Clear it and defrost the unit so it can start with a clear drain line. It may solve your problem. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 08, 2010
    Genius:
  • 1,478 Answers
Before jumping to conclusions about why your refrigerator is leaking, do a thorough inspection. Many times, it will be easy to see where the water is coming from and from that point deduce the problem. For instance, water leaking from the back is usually due to an ice maker issue, water from the side of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan,a clogged defrost drain pan.
You need to clean the drain tube and check the ice maker and refrigerator level for water inside the refrigerator.
Take care.
Posted on Sep 07, 2010
Water is frozen in fill cup inside the ice maker
Put your frozen food in a cold place.Unplug the fridge, leave the freezer door open for 12 hours. Dont mess with hair dryers
Jan 30, 2013 | GE GSS25LGM Side by Side Refrigerator
Hello- I have a Kenmore Elite refrigerator model# 795.77563600 which leaks a small amount of water under the front left corner only after every 1-2 uses of the water dispenser in the door. I've...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 18, 2011 | Kenmore Refrigerators
I have a aeg santo 91842 4i, integrated fridge-freezer, just over 2 years old.-i know just out of ganantee!! it keeps leaking water from the bottom, (underneath the freezer compartment),and i just cant...
If the drain is clogged with Ice or ? it overflows into the ref.
Leo Ponder
imufo2
Aug 07, 2011 | AEG Refrigerators
Water leaking from the bottom of frig
Your  deforst drain is clogged.  Every 12 hours or so your fridge does a deforst cycle.  It melts all of the ice built up on the evap coils.  There is a drain at the back of the fridge that goes to a pan by the compressor where the heat from the compressor and the condensor coils evaporates it.  Take the back panel off of the freezer compartment and plunge out that hole.  You will most likely have a build up of ice over the top of the drain.
May 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Water leaking from bottom
Between your freezer section and refrigerator section there is a draintube that allows water to flow from the freezer to the fridge during defrost. You will need to remove the rear wall of the freezer to access the freezer part and the center console of the fridge if one is there. Once you have determined that tube is cleared of ice you will need to continue tracing where the water flows which is usually at the top of the fridge section in the rear center. It goes out the back wall there. Make sure thats all cleared and pour a small cup of water in the freezer part to be sure its clean. Observe the water flow all the way out of the tube to the lower part of your unit into the drain pan which is located at the very bottom or in the rear on top of the compressor.
May 22, 2010 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Small pool of water underneath Whirlpool fridge
There may be a water filter built in. Look for access lower front panel below door. recommend replace every year. They will leak when neglected.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
At least once a day water leaks from underneath my fridge. Can't seem to trace it back. The ice maker line and hook ups are ok. I think it may be coming from inside frige but not sure. any suggestions?
When the automatic defrost cycle runs, the refrigerator has to drain about a quart of water into the catch-pan beneath the fridge, where it evaporates.
Look for the drain tube at the bottom of the freezer and make sure it is not blocked. Remove the lower-front kick panel and, of this model has a drain pan, make sure it's installed and not knocked out of position.
Some units use a little plastic bucket instead of a catch-pan, and sometimes these are sized too small so that they overflow easily.
Some fridges have a 'humid/normal' switch which prevents condensation from forming on door seals.
Oct 23, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Leaking into the fridge
on the back or underneath it should go into a pan under the fridge
Aug 08, 2009 | Kenmore 60721 Refrigerator
Water leak below fridge.
Have you left an air space behind the fridge to allow the natural convection of the heat from the motor to dry the condensate from the tray on top of the motor
By moving it forward and taking off a grill you have improved the airflow ??
May 25, 2009 | Refrigerators
Refrigerators Logo
116 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
