Question about AmcorAire UCHW-H18AF2 Split System Air Conditioner
AmcorAire Duo. Compressor runs, but fan will not. system shuts off after a rew minutes (overheating coils?). Has the fan burned out or is there a relay that needs to be re-set?
  • 73 Answers
There is a solid state fan capacitor for your system, I would change that part first.
We stock a complete line of parts for Amcor Mini Split Systems.
Support@Pridiom.com
201-266-8234 option 2
Posted on Jan 04, 2011
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
After 10 minutes car engine start a/c goes off
Possibilities:
A: If the compressor turns off but the circulation fan continues:
  1. Insufficient refrigerant charge;
  2. Refrigerant overcharge, causing evaporator coil freeze-over;
  3. Defective compressor clutch;
  4. Clogged screen in orifice tube;
  5. Front condenser coil is clogged with dead bugs, dirt, foliage, or other material.
B: If the entire system turns off, including the circulation fan:
  1. Defective system breaker;
  2. Defective system relay;
  3. Defective climate control module (at dashboard);
  4. Fan motor overheating due to clogged air intake or other obstruction;
  5. Fan motor overheating due to debris in air handler box, such as leaves or other plant debris.
Jul 17, 2014 | 2000 Kia Pride
Conditioner Fan
this a split system? inside and outside unit? possible relay( if it has one) or contactor. make sure 230 volts at contactor.
Feb 19, 2014 | AmcorAire UCHW-H24AF2 Split System Air...
Can you operate an amcoraire duo UCHW-H12AF2 without a remote control?
The unit will run @ 75 degrees without the remote. Go to Ebay.com
Search Amcoraire Remote Control, you will find what you need.
Jun 24, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Reaons for hussman freezer compressors failuer Model No:NLD 2
Normally compressors fail due to overheating. But just like any machine that may run 24 housr a day 7 days a week, the compressor may just wear out. Overheating is caused primarily by stopped up condenser coils. The condenser coil is the radiator like object that sits close to the compressor and dissapates heat created by the compressor. Also if the fan behind the condenser coil fails because of an obstruction or fan motor burnout the heat will not be dissapated properly. The compressor has protection built in that should shut it off during an overheating situation, but it can't protect it over a period of time where the compressor keeps trying to start and shuts down due to overheating. If you look at the condenser coil in many cases you will find dust and or grease build up so dense that no air flows through the coil. This is simply neglect or not knowing that the coil needs to be cleaned periodically. Also, if you have a refrigerant (freon) leak, your compressor will overheat. The cold returning freon helps to keep the internal components of the compressor cool as well as keeping the oil inside the compressor churning up onto the internal components. If you have a leak, it is not sufficient to just add freon every once in a while. Leaks need to be fixed by finding the leak and welding the leak shut. No refrigeration system should require "gassing up" other than the initial charge of refrigerant. Overheating can also be caused by a lack of air flow through the condenser coils because there is no space around the machine for air to flow into and out of the compressor compartment. If you have recently replace a compressor and it goes bad again, it may be burnout residue from the previous compressor that clogs the lines after a burnout. I hope this answers your question.
Oct 12, 2010 | Freezers
We have: AmcorAire Duo Ductless Split Air Conditioner 24,000 BTU Cooling & Heating UCHW-H24CF2 by Pridiom. The tech says the compressor is shot, but Pridiom (who bought AmcorAire or what Amcor...
Amcoraire Closed their doors Aug/Sept 2009. Pridiom Group started operations October 2009, Pridiom purchased Amcor parts/equipment at bank sale. ANYTHING PRIDIOM SELL'S, PRIDIOM WARRANTS to be free of defects parts 3 years/5 years compressor. It is that simple.
Support@Pridiom.com
Jun 24, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
A/C starts up/Cools/Fan Slows, Unit Shuts down in 4 minutes
Ensure proper voltage to the unit. Check for overheated/damaged wires and/or connections in the control panel as well as at the fan motor and compressor.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
Amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jun 30, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
Blower fan runs at one speed - very low
There is a sensor on the indoor coil that needs to reach a certain temp before the fan speed will increase. Sounds like the unit is undercharged if the sensor isn't reaching the temp it needs to.
Mar 09, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
AmcorAire  UCHW-H18AF2 Split System Air Conditioner Logo
248 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
