Question about Kenmore Dryers
Have a Kenmore 11076832500 gas dryer. Unit heats up sometimes and sometimes doesn't. What should I look for?
  • 1 more comment
  • craigm753 Sep 07, 2010
    Thanks. That is what I thought, but always good to get a second opinion. If that isn't it will contact you later.
  • craigm753 Sep 09, 2010
    Thanks for the advice on my Kenmore dryer. Dryer works great.
  • craigm753 Sep 10, 2010
    Well the thermal fuse got me going for a few hours. Now back to intermittent service again. Could it be the timer?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. No heat issue is this type of dryer is usually cause by the Thermal fuse going bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
Gas dryer 11076832500 no heat
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
May 26, 2014 | Kenmore 7842 Dryer
DOESNT HEAT AND I SMELL GAS
Hello - From what you are describing, if the dryer only heats up sometimes but provides a gas odor, it could possibly be a defective gas supply or igniter. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the fuse for the dryer. Turn on the dryer and select a normal cycle. If it proves to be ineffective and if the issue continues I suggest contacting a professional to move forward accurately. Keep in mind since it is such a complex unit, the technician will likely verify that it doesn't have a defective sensor, control board or high limit thermostat.
Oct 13, 2012 | Frigidaire GLGR341AS Gas Dryer
Kenmore dryer stackable unit, no heat coming from dryer, all else works
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite model #110.95088400 that doesn't heat when drying. I checked the thermal fuse and it goes to continuity. I checked the hi limit thermostat and it was continuity, the thermistor...
heatman101
Aug 24, 2011 | Dryers
Dryer not heating. It started to but quit. I also needed to replace the ground fault outlet the unit is pluged into. Prior to the replacement the dryer did the same intermtent heating. Now no heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 04, 2011 | Kenmore 72622 Gas Dryer
Heating unit on whirlpool dryer not working
heatman101
Jan 23, 2011 | Whirlpool Dryers
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Kenmore dryer Model #6507923 Gas sometimes won't
You may have a bad thermocouple. The thermocouple senses the heat from the flame and "tells" the control unit that the flame has lit. If it is sending no signal, the control will think it didn't light and shut off the gas to prevent an explosion. Good luck.
Jan 03, 2010 | Dryers
Kenmore Model 110.76912691 gas dryer that heats intermitently
Replace the solenoids on the gas valve. These are often intermittent befor total failure. Hope this helps!
Feb 26, 2009 | Kenmore 63942 Dryer
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Dryers Logo
77 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
