Question about Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728
Need to reinstall Schlage deadbolt and knob after painting
  • 1,498 Answers
Ok. So what is the problem? The reinstall should be straight forward.
I'm Mike BTW
Posted on Sep 07, 2010
How do i remove the plugs covering the screws on the schlage deadbolt?
Schlage FAQs Schlage
The double cylinder deadbolts are keyed on both sides. On the interior side of the home there are drive pins (sometimes called screw covers) covering up the screws. Recommended method: Indent the center of each drive pin with a nail punch. Then use a carbon tip drill bit (about the size of a pencil lead) and ONLY go down 1/8". The drive pin will disintegrate. The drive pins will need to be replaced as they are no longer usable.
Sep 16, 2014 | Schlage Deadbolt. Double Cylinder Deadbolt...
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Will a schlage b60 fit in the same holes as a schlage regent deadbolt
I'm not sure what the regent deadbolt is, but if you look at the attached Factorylocks.com youtube video it will show you how to resize a Schalge B60 deadbolt.
Dec 18, 2012 | Locks & Locksmithing
Schlage deadbolt
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
You also need to check the operation with the door open versus the door closed--to make sure that you haven't developed a mechanical bind between the door and doorjamb. If all else fails, the lock should be under warranty!
Jan 26, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Schlage camelot key pad does not engage exterior locking knob when you press the schlage button. I have tried three different locks.
Here is a link to the installation instructions:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
It sounds like you may have the Turn Lock Feature disabled. View and scroll down in the instruction sheet to the Troubleshooting portion, where it says " Pressing (the) Schlage (button) does not rotate deadbolt" The solution is to push the PC button, then the Schlage button, then 7 to enable the turn lock feature.
Here is the contact info you need for customer service:
Olathe, KS 66061
May 02, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Keypad indicates green but does not unlock door. Neither does the inside knob. Key opens door. New Battery.
Olathe, KS 66061
Jan 20, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
How to reinstall a Schlage deadbolt
deadbolt wont lock on inside of door only on the outside
Oct 09, 2010 | Schlage B362 716 DBL CYL DEADBOLT EA...
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
How do you remove knob on schlage deadbolt so that you may remove faceplate to tighten screws ?
turn knob as usual, there should be a hole in the bottom after you turn it. push a small screwdriver and it will pop right off.
Apr 04, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728 Logo
167 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Jim Thurston
Mike
Tom Weglarz
Tom Weglarz
Level 1 Expert
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
