Question about Sony VAIO PCV-RX511 PC Desktop
How do I replace dvd or cd on a Sony pcv 7732
  • 16 Answers
SOURCE: CD/DVD ENCLOSURE in Sony Vaio PCV RX860
http://esupport.sony.com/US/perl/tutorial-display.pl?tut_id=269&mdl=PCVRX860
this link is a tutorial of how to get the side panel off,
to get the cd drive out, you need to do a couple more steps.
first, you will need to take off the top and other side panels. this can be done by looking at the top back of the case. there are two clips that hold the top panel on. push up on the two clips and the top part will slide back and you can pull up on the panel and it should come off.
Next, you should be able to push some more clips on the top to get the side panel off. it should fold down just like the first side.
then, you need to take off the front two panels. the bottom part should be just a couple clips on the inside front of the case, and the top clips will be revealed when you take off the bottom part.
after that is done, you should be able to unscrew the cd/dvd drive from the case and unplug the cables connected to it from the top where you removed the top panel.
then you should be done
Posted on Jun 05, 2008
  • 37 Answers
SOURCE: sony pcv-rx860 dvd drive will not open to remove cd-
Hi, if you look at the front of your cd drive you will see a little hole. This is an eject mechanism. If you insert a paperclip in this whole you should be able to manually push the drive open. Once it is open it may release what ever is causing the drive to jam.
I hope this helps.
Posted on Mar 20, 2009
20YrsCompExp
  • 227 Answers
SOURCE: Install wireless card
http://www.retrevo.com/s/Sony-PCV-7732-Desktops-review-manual/id/904ag616/t/1-2/ Try that link many of manuals on the 7732 users, operation, troubleshooting....
Posted on Apr 01, 2009
the_fire
  • 432 Answers
SOURCE: will not read or burn dvd's
can it read or playback normal dvd's ie a movie that you have purchased from a shop or rented ?
If not then the dvd laser has gone in your dvd / cd rw drive in which case you need another dvd drive.
If it will play back normal movie dvds then that indicates that your computer can playback dvd's and hence the laser is working but maybe the other dvd drives / recorders are not closing the dvds correctly maybe ?
Not sure - some more info from yourself would help.
Posted on Apr 11, 2009
tommya300
  • 724 Answers
SOURCE: Do you have any service manual for the Sony all in
Desktop by anyother name is still MS PC.
Any over the counter CD DVD CDRW will operate just fine all you need it the softward that comes with it to burn. Everything else is a standard It was different in the early to mid 90s for just the cd players. Not today!
Posted on Jul 24, 2009
Does my sony pcv-7732 have a wireless card?
Sony PCV 7732 Manuals Support and Troubleshooting VAIO Desktops
This is an older Pentium based XP machine and does not have built in wireless networking. You can, however, add it
May 19, 2014 | Sony VAIO PCV-V200G PC Desktop
I wiped out the dvd and cd driers on my son pcv-rs310
Uninstall both of the drives from Device Manager located under My Computer and then scan your computer for new changes it should detect the drives and it will install the driver itself hopefully you are using win 7 or vista it will install the driver itself.
Jul 20, 2012 | Sony VAIO PCV-RS310 PC Desktop
Cd\dvd drives not working on PCV-RZ49
hmmm..perhaps you need dvd or other reading software? go to www.sony.com enter model number then search on dvd software for that model
Jun 13, 2012 | Sony VAIO PCV-RZ49 (T99861234) PC Desktop
Replacement for Sony Vaio optical disk
Your computer is an older pentium 4 PC. As such it uses ATA / IDE - EIDE drives. These days stores sell SATA drives but IDE drives are still VERY COMMON. You can find tons of them on eBay or your local computer store (for much more than eBay). The original drive has a 24x CD reader, 8x CD-r writer and a 4x DVD reader. It does not write DVDs. You can buy any ATA/IDE drive you like and now you can probably afford a DVD burner too.
Apr 23, 2010 | Sony VAIO Digital Studio PCV-RX670...
I have a Sony Vaio desktop with XP. My DVD-CD
Have you tried burning a CD in the new drive? Because the drive is a DVD it will always be recognised as a DVD, but should work perfectly well with CDs both playing and recording.
Nov 07, 2009 | Sony VAIO Digital Studio PCV-RS220 PC...
Sony dvd drive automatically running without any cd or dvd
you will need to go to the Sony website to the support web page and download the latest firmware for the drive.
Good luck
Oct 20, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Where can I get a new DVD Cd for my sony pcv-v200g.
Hello
please check first the bios settings check the boot priority select the 1st boot priority to cd or dvd rom then exit and save while inserted the bootable cd..
Angel
Thanks..
Aug 02, 2009 | Sony VAIO PCV-V200G PC Desktop
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Will not read or burn dvd's
dear friend
this is common probs for notebook dvdrws
they lack quality (all brands)
after sometime drives stops writing dvds, then reading them
after sometime, writing cds and eventually reading cds
in 5-6% cases drives stops to read cds first
sorry friend you have to replace the drive
and if it is in warranty
go for rma
thanks
Apr 11, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Apr 01, 2009 | Sony VAIO PCV-V200G PC Desktop
Sony VAIO PCV-RX511 PC Desktop Logo
208 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
