Question about Magic Chef MCBR440 Compact Refrigerator
It wont run. I plug it in and nothing happens. No noise, no cool air, nothing. I have tried multiple outlets as well
    New Friend:
  • 50 Answers
Check if there is power going to the compressor,check the wiring
Posted on Sep 07, 2010
Not working
I literally had to have mine on it's own outlet with nothing plugged into the secondary outlet, also if it's on a line, ie; older house, again no other electricity can be pulled from the outlet or the machine knows it doesn't have full power. Also, I reset on the plug itself a good 5 times while plugged in and not plugged in, eventially, it worked for me. Good Luck.
Jul 27, 2014 | Haier 12,000-BTU Commercial Cool Portable...
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
I was watching tv then it shut off i tried multiple outlets but still wont turn on the little light in fron does turn on but nothing else
When you try to turn on the TV that when the light on front comes on or is it on when you plug in the TV to an outlet? I
Aug 28, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
The unit just stopped working and will not turn on
I'm assuming 'nothing' comes on when you try to run the AC unit. If the fan runs but the AC does not cool then ignore the below info, but if "nothing comes on" then proceed with the below info.
If the breakers are not tripped and you've tried other outlets (on different breakers) I would suspect a faulty switch. You can replace the switch ( If it's not computerized). First unplug the unit from the wall and locate the switch (it will be the one that has the knob that controls "fan, Hi Cool, Lo Cool, etc etc.) then remove the switch - 'being careful to mark all the wires in such a manner you can replace them on the new switch, exactly like they came off the old one.'
Then if you take the switch to an appliance shop and can find/order the 'exact' same switch (or at least a comparable replacement with the same connections as the old one) you could re-install it on the unit, connect your wires back up to the switch and plug it back into the outlet and see if that was your problem.
good luck!
May 03, 2010 | Goldstar M6004R Air Conditioner
Hot chain saw wont start
When it won't start, remove the spark plug, lay the base on engine metal with the wire on, and pull through. The spark should be blue and snappy. If nothing, try a fresh plug. If still nothing, the ignition module may be failing with heat. Try blowing out sawdust from the engine and case with compressed air to improve cooling. Does the engine 4-stroke when not cutting, but immediately 2-strokes when cutting? Check the air cleaner and muffler for plugging. Make sure the carburetor fasteners are tight. Hope some of this helps!
May 01, 2010 | Garden
I am having HP pavilion Dv6703tx model laptop,But my problem is that it's making a noise i mean fan noise.so please help me how to remove this noise.
This can be because of two reasons.
First : Dust is settled in your fan surrounding and the air in/outlets. Cleaning the dust can reduce the noise upto a great extent.
Second : The processor got older and now the fan has to over work to take away the heat, this happens with the aging of the laptop. Some processes and programs may overload your system, so it can also may be a cause.
Try a complete virus scan. Clean the air outlets near the fan. Here are the ways to clean the outlets.
The first easy attempt: Blow hard into the cooling fan air inlets and outlets. Chances are good that the fan noise decreases immediately.
Second more serious attempt: Open up your laptop (be careful!) by for instance, depending of model, removing the keyboard usually by removing a couple of screws on the back of the laptop and maybe some locking straps on the front. Then remove all dust you can see by for instance blowing hard on and around the cooling parts mentioned above. Note: Saliva and laptop electronics is not a good combination so be distinct but careful. Good luck!
Apr 18, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
Magic Chef MCBR440 Compact Refrigerator Logo
75 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
