Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Printer Problem It shows the message LSU error and can not Print or copy any document.
  • Rohit Jamuar May 15, 2008
    the printer model is PE220 made by xerox
    President:
  • 2,072 Answers
What model printer is this? The C2424 does not have a laser.
Are you 100 percent sure it is a model C2424?
There is no LSU status code for that machine.
Posted on May 14, 2008
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
The printer shows LSU error, When i Turn it of after 2 or more hour I can print max 3 copies and then the same error appier (LSU error).
Hello my friend this is Laser Scanner Unit error and this is probably cause if the polygon motor in the LSU does not rotate.The LSU’s laser beam is
functioning properly.You can try unplugging the machine for 3 minutes and plugging back in before you do anything else.If this does not fix it you will need to have it serviced.
Feb 03, 2010 | Samsung Office Equipment & Supplies
LSU ERROR
i have a Samsung all in one Laser printer, its shows me LSU Error when i am going to print any document or if i want to make copy.so can u tell me how can i solve this problem
Dec 23, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
LSU error message
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
LSU error code
Do you have the old cartridge? Because the message you are getting makes no sense if you can copy and not print.
The chip on the cartridge may be corrupting the machine software.
I will explaine why I say this. LSU fault, is a failure of the laser unit within the printer/copier. If it had failed, you should not be able to copy or print, The machine should not function. The laser unit is what makes the image on the drum. So neither print or copy should work if that was a true LSU code.
Did you purchase a cartridge made by another company other than Xerox? If so try returning it.
As I say, an LSU code should make the machine totally unpoerable, not partially functional.
I would try the old cartridge if you have it to see what happens.
Let me know if you have tried swapping cartridges and I will look into this more for you.
Sep 16, 2008 | Office Equipment & Supplies
Problem with copy
LSU Error is showing the printer and is in non working condition
Nov 09, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
249 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
