Question about Wharfedale Evolution 20 Main / Stereo Speaker
My tweeter stoped workin so i took speakevr back to shop thay have said its still under manurfacters warrenty so thayll see what thay can do my partner rang them today and was told that thay have had to send the tweeter to aig for testing to find out if it was my fault and if it is thay will have to bill me to fix it but ive only had them a month and used on for 8-9hrs at num6 on my amp which goes up to 20 so i cant have broken them my ques is does this sound like normal pract or am i being riped off.
    President:
  • 1,139 Answers
How they can even imply that it could be your fault is beyond me. Considering it is still under warranty they should be replacing it no questions asked. As long as the speaker is capable of taking the signal sent to it, which I have no doubt it is, then they should not be questioning you at all. I would seriously consider talking to a supervisor and start quoting the law to them about sale of goods act etc etc. See them squirm when you start talking about consumer rights.
Posted on Sep 07, 2010
Rotater bar not workin on dc50 dyson 2016 model...took apart and completely cleaned but still not working
common fault with this model is the PCB blowing. phone dyson under your 5 year warrenty for free repair
Aug 23, 2017 | Dyson Vacuums
How do i go about geting money back off currys for a laptop
not true if the laptop was faulty when you bought it then thay have to give you your money back or replace it or repair it.
Apr 01, 2015 | Computers & Internet
Have 2 jbl 615 get good base and sub but neither tweeter playing
You will need to determine if it's the amplifiers or the tweeter themselves that are not working. If you open up the cabinets and check each tweeter with an ohm meter for continuity it will show if the tweeters are working, in which case the amp is the problem. if the meter shows that the tweeters are blown, you should still hook up another tweeter or speaker to the horn amp to see if it's blown and therefor took out the tweeters.
If any of this sounds complicated, you'd be best off taking the cabinets to the repair shop.
Mar 16, 2015 | JBL Audio Players & Recorders
How do I get the password for my Phoenix room bios plus version 1.10 and Dell system optiplex gx400
Hi
If you set the password there is no way to recover it and thay don't normaly use default passwords now the default us null.
To clear the password (only do this if your laptop is out of warrenty) remove all power and remove the battery, open the case and locate the BIOS battery on the mainboard remove it leave it out for 1 -2 mins and replace put the the case back on replace the battery and there should now be no password on the BIOS you should have access.
If you are not happy removing the case take it to your local PC Repair shop and thay will do this for you
Cliff Cook
MCP
Jul 29, 2014 | Computers & Internet
My concept amp just stoped workin just now i took off the back panel but evrythin looks ok what might it be?????
remove the back panel and look at the other side of the board, thats where u might see sum burn marks. or with amp powered up and back panel on jiggle the solid bar wires with a pair of insulated needle nose, maybe came loose from there. had that happen to me once with a memphis prd1000.1. soldered it back to the board and it pounded again
Feb 19, 2010 | Concept CD-2410 Car Audio Amplifier
My visio tv stoped turning on lately.
Hello threefreecol, This is a common problem related to the capacitors on the power supply board. What you can do is to take the back off of the TV and look to see if any of the capacitors on the power supply board are bloated or puffy (signs of damaged capacitors). If they are change them out with new ones (you are going to need a soldering iron and a desoldering pump to do this). In any event this is a power supply problem. I believe your TV is still under warrenty, so you may want to take it to a shop the honors the VIZIO warrenty program. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 12, 2009 | Vizio L32 32 in. LCD HDTV
I can't get my mouse to work properly on my ML6732. The right button and center pad isn't working properly...
if its on warrenty : take it back to shop not on warrenty: Take it back to shop If u wanne Experiment and try urself: Look under the pad.
Jun 05, 2009 | Gateway ML6732 Notebook
Leens has cracked on in side thay camera but it is still under warranty
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Due to the crack the lens is concidered to the manufacturer out of warrenty.
Apr 30, 2008 | Cameras
Turntable problems
buy a better record player
Sep 27, 2006 | Emerson NR303TT CD Shelf System
Wharfedale Evolution 20 Main / Stereo Speaker Logo
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
