The service manual is here:
http://www.microwavedisplay.com/r1600_r1601_r1602_sm.pdf
If when you try to cook the oven lamp comes on, but fan and turntable do not, then you have a bad bottom door switch or mount, and you should see these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Any unusual noises? Is
it louder or quieter than usual?
We have a sound clip of
what a microwave should sound like when the cooling fan and high
voltage section are operating here: http://www.microwavedisplay.com
A loud buzz, hum, or groan is usually a
shorted high voltage rectifier diode, but a sound like gurgling into an
empty coffee mug is one symptom of a failed magnetron, and yet the mag can
be bad without that sound.
Here are some links you
or someone you know can use (in order given) for test help, but read
the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking,
it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even
though mag is bad!)
You can order
parts for this brand from Encompass or you can call them toll-free at 866-779-5835.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
