Question about Dell Inspiron 530 -Intel® Pentium® dual-core processor E2180 , Genuine Windows Vista® ... PC Desktop
Every time I leave my computer for a few minutes I must enter my password to restart even if I have not closed the program...what is happeining? this is a recent problem.
  • 385 Answers
Do to control panel, display properties, screensaver, and uncheck the box that says require password when resume
Posted on Sep 07, 2010
Dell optiplex 760 locked me out and ask for system password and I don;t know it, what do I do
If you've never defined a password, leave space blank and press enter. Maybe should accespt it as password
May 26, 2015 | Dell OptiPlex Computers & Internet
BIOS-upgrade not working. Now Bios needs Passw. And a license is gone...
Locate Phoenix BIOS Passwords
The basic input/output system, or BIOS, is a program that acts as a digital liaison, managing communications between peripherals and the operating system.
Because the BIOS is critical to the operation of a PC, some computer manufacturers and workplaces employ a password for security.
If the password is lost or has been reset through electrostatic discharge, it would be impossible to guess without the aid of computer forensics.
Sometimes you can gain access to the BIOS through the keyboard, depending on the computer, but typically the solution is mechanical.
Contact your computer manufacturer.
All computer manufacturers have websites with technical support available.
Have your computer model number and serial number ready.
If the manufacturer is unable to help locate a password, standard back-door passwords may help.
So-called back-door passwords may help you access the BIOS.
Try using the following back-door passwords to access the BIOS: phoenix, PHOENIX, CMOS, BIOS. BIOS passwords are case sensitive.
Contact the motherboard's manufacturer if the back-door passwords failed.
Find the motherboard's website for technical support.
You will need to open the computer case if you do not know the motherboard brand.
Electrostatic discharge can reset a BIOS password.
Shutdown and unplug the computer.
Unplug the monitor and all peripherals from the PC, including speakers and USB devices.
Ground yourself by wearing an antistatic wristband clipped to the metal case, or touch something metal before you open the case.
Use the screwdriver to loosen and remove the screws from the case. Look for the motherboard, the largest circuit board inside, attached to one side of the case.
5
Printing on a motherboard can be hard to see without a magnifying glass.
Examine the motherboard for a brand name.
A good place to start searching is near the processor, the large square box on the motherboard. A flashlight and magnifying glass are especially useful for a clear view of the motherboard.
The brand name could be printed anywhere or, sometimes, not at all.
6
The motherboard battery is round and fairly flat.
Locate the CMOS battery while you have the case open.
If contacting the motherboard manufacturer failed, you will have to remove the battery.
The battery is circular, about the size of a dime, but as thick as two to three stacked dimes.
Do not disconnect or remove anything yet.
Removing the CMOS Battery
7
Note the location of any cables that need to be disconnected.
Use the digital camera to take pictures of the motherboard, or sketch the location of cables and connectors.
f any components or cables need to be moved or unplugged to reach the battery, you want to remember their exact location.
8
Leave the battery out for at least 20 minutes.
Remove the CMOS battery carefully so as not to snap or break the clamps.
Leave the battery out for 20 to 25 minutes to allow the capacitors to completely discharge any memory. Avoid touching anything else in the computer.
9
Tighten the case screws when done.
Return the battery to the motherboard, and reconnect any cables that were disconnected in the case. Close the computer case and tighten the screws.
10
Look for the setup message on the monitor.
Turn on the computer and closely watch the monitor for the "Entering Setup" message that appears before Windows starts.
The message will tell you which key to press to enter the BIOS setup.
You may need to reboot a few times to see the message, as it appears on the screen for just a few seconds.
11
Carefully read the settings information on the monitor.
Follow the directions on the monitor for changing the date, boot sequence, and any other settings.
Work slowly and read the screen directions thoroughly.
Be alert and cautious.
Once the settings are saved, the system will start, and the password will have been removed.
http://www.computerhope.com/help/phoenix.htm
Phoenix BIOS help and simulation
Recover Phoenix BIOS
Although most people think the operating system is the core software required for a computer to run, without the computer's BIOS, then the operating system cannot even launch.
When a BIOS installation encounters a problem, it can cause components of the computer not to function correctly or it can cause the computer itself not to function at all.
It is possible to recover the BIOS of a computer, if you know what sort of BIOS the computer's motherboard uses.
The recovery process should take approximately 5 to 10 minutes, during which your computer will seem mostly unresponsive.
Download a crisis recovery program designed specifically to restore damaged or otherwise non-functioning copies of Phoenix BIOS.
Read the instructions for using the recovery program to make sure that no specific changes or configurations need to be done to it before it is used.
Place the Phoenix BIOS recovery program and its files onto a blank disc or a USB drive according to the program's instructions (this usually simply consists of extracting the files from an archive.)
Once the program and its files are in place, insert the disc into the computer's drive or plug the USB drive into an available USB port.
Hold down both the Windows key and the "B" key on your keyboard and press the power button on the computer.
(On some laptop computers, you will need to press the "Fn-B" keys instead.)
Wait for the disc drive light or the USB drive access light to start flickering to show that the computer is accessing the Phoenix BIOS recovery program, and then release the keys.
Wait patiently while the Phoenix BIOS recovery program overwrites the damaged sections of the motherboard's current BIOS installation.
Depending on the computer and the recovery program used, the computer may or may not reboot once BIOS recovery is complete.
If the computer does not reboot on its own, wait at least 10 minutes before manually restarting the computer to make sure that you do not interrupt BIOS recovery.
Eject the disc or remove the USB drive before rebooting to prevent accidentally reloading the recovery program.
Reboot the computer and watch to make sure the Phoenix BIOS screen appears as normal. Once the BIOS loads properly, your operating system should launch as normal.
http://www.theeldergeek.com/forum/index.php?showtopic=21209
http://www.rechner.org/b1800.html
Jan 05, 2014 | Computers & Internet
I factory reset my gateway zx series all-IN-ONE because the recovery disks i created wouldnt work.then i reinstalled windows and now i have nothing in my programs list n i cant log in cuz they want a...
Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management." Click "Restore" when the Gateway Recovery Management window pops up, which will take the system back to the default factory specifications. A box will pop up asking for confirmation, click "Yes" and then "Start." You may have to enter a password as well, but only if your particular Gateway had a password set. Wait for the computer to restart. A "Restore from factory default" box will appear, requiring you to click "Next" twice in a row. Click "OK" in the box that appears next, and wait for the hard drive partition to be created. The factory default installation will then be moved over to the hard drive. Click "OK" in the box that appears and wait for a second Gateway restart. Several minutes will pass as Windows "starts for the first time." When restarting finally finishes, a "Set Up Windows" dialog box will appear. Click "Next," followed by checking the license agreement box, and then "Next" again. Enter a user name and picture, if desired, and a computer name. Also, customize the background wallpaper for your desktop, optionally. Click "Next." Click "Use Recommended Settings" on the Protect Windows-based dialog box that pops up. Set your correct date and time settings in the next box. Select your location in the following screen. Click "Next," followed by "Start" to finish. Wait while Windows checks for your individual Gateway computer specifications and adjusts accordingly. This will likely take several minutes, so leaving your computer for a short time is fine. Windows will then prepare your hardware and finish your Gateway restoration process, including the installation of Gateway Recovery Management. Once completed, your Gateway is good to go and ready at factory settings.
Hope this helps.
Jan 21, 2013 | Computers & Internet
I locked my computer with a password and now I cannot remember the password. How do I unlock my computer?
  • 1Hit "Control," "Alt" and "Delete" on your keyboard all at the same time and hold them for a few seconds. Select "Restart" from the list of options presented in the Task Manager. If you cannot get to the task manager using this method, manually shut down your computer by pressing and holding the power button. Wait about 30 seconds before turning the computer back on.
  • 2Wait for the computer to get to the Windows logo then press and hold "Control," "Alt" and "Delete." The classic login box will appear. Type "Administrator" in the dialogue box marked "User" and leave the password box empty. Click "Sign in" or hit "Enter" and wait for Windows to load the administrator profile.
  • Click the "Start" button on the bottom-left corner of your screen. Scroll through the list of programs until you find "Control Panel" and open it.
  • 4Locate the "User Accounts" tool. In the "User Accounts" window, select the password tab. Locate the account that you wish to reset the password for and select the text box with the black dots in it. Delete these dots and enter the password that you wish to use. Re-enter the new password in the "Confirm New Password" area. Click "Apply."
  • 5Close all of the open windows. Then, click your "Start" menu and select "Restart." Wait for Windows to restart and this time allow it to boot up normally. Enter the new password into the "Password" dialogue box and hit "Enter."
  • Source: http://www.ehow.com/how_6066989_troubleshooting_-unlock-computer.html
    Feb 25, 2012 | HP Computers & Internet
    I would like to break my computer password which has been given to the computer
    Resetting password user name & password: b> *Start your computer
    *Keep pressing "F8" as the computer starts.
    *This will enter the computer in Safe Mode.
    *(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
    *Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
    *Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
    *Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
    **Restart computer and login into the account you just created using your newpassword.
    Sep 16, 2011 | Microsoft Word for PC
    I lost my password my screen is locked how can I reset or bypass?
    This is about topic bypass Windows logon screen. Command Prompt or recovery utility is effective ways for reset or bypass lost Windows password.
    First, run command prompt with administrator. And you can reset Windows lost password with this command. Net user <new user> <new password>
    Second, take recovery utility to burn a password reset disk. And this reset disk is the key to remove or reset Windows password, applied for standard or admin account. When your computer is installed with Windows 8/7/Vista, forgotten user password would be removed. If it is Windows server 2012/2008 etc, password would be reset as "iSunshare@2012".
    Mar 18, 2011 | Sylvania G-Netbook
    My daughter has put a password on her account and set it up as admin account, but has forgotten the password, how to we change password???
    Hi zbarratt,
    (I'm assuming that you're problem is in your computer/laptop) All you can do now is to reset the c-mos to erase the password. You have to pull-out the internal battery of the c-mos. This is like the watch battery. Leave 5 mins then re-insert. Power on the PC and you can access it again...
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
    Mar 14, 2011 | Computers & Internet
    I forgot my password to my sylvania(SYNET7WID) netbook how do I unlock it
    This solution will work if you have forgotten your Windows password. It will not work if you have forgotten your boot password or hard drive password etc.
    Read on if you want to use a USB flash drive. Scroll down if you would rather burn a CD/DVD.
    USB Flash Drive Method
    You need to download a Windows password cracker, put it on a flash drive, and boot it outside of the Windows environment. This solution will show you how to do that.
    1. Download the Ophcrack Windows password cracker from here. For Windows 7, click on the ophcrack Vista LiveCD. Ophcrack is one of the best free Windows password recovery tools available. It's fast and easy even for a first time Windows password cracker. Save file to Desktop.
    2. Download Xboot 1.0.0.0 Beta 6 here. Save file to Desktop. Unzip file and extract to Desktop.
    3. Plug a USB flash drive into your PC and format it with a FAT32 file system. This can be done by opening "My Computer" and right clicking on the USB flash drive and selecting Format. Select FAT32 and click OK. (Note: this will erase all data on your flash drive.)
    4. Open Xboot.exe. Select the Ophcrack ISO file you downloaded and drag it onto the Xboot screen.
    5. Click on "Create USB" found i
    n the bottom right hand corner of the Xboot window.
    6. Select your USB drive and click OK. Wait for your USB flash drive to be created.
    7. Restart computer and press F10 or appropriate function key for your computer to enter the temporary boot menu. It may be F12 or F9 etc. Look at the first screen that appears when you turn on the computer and you will see which key to press. You also could enter the BIOS and change the boot order if you would prefer that method.
    8. Select USB Flash Drive from the boot menu.
    9. The Ophcrack LiveCD will now boot. Hit enter to select the Graphic Mode option when it appears.
    10. Ophcrack will automatically begin cracking your passwords. The longer and more complicated the password is the longer it will take to crack. 99% of passwords are crackable. Any password over 14 characters cannot be cracked. This program found my 8 character password which contains letters and numbers in less than 10 minutes.
    11. Write down your password when it's cracked. Remove the USB drive and restart computer.
    Good luck and thanks for using FixYa.
    Burn a CD/DVD Method
    You need to download a Windows password cracker, burn it to a CD/DVD, and boot it outside of the Windows environment. This solution will show you how to do that.
    2. Burn the Ophcrack LiveCD ISO file to a CD/DVD using the Windows 7 Disk Image Burner or another burning program. For Windows 7 users, please follow steps 2a and 2b. If you are using Vista or XP you will need to use a CD/DVD burning program already installed or download and install a free program such as the one here.
    2a. Right click on the ISO file and select "Open with" and then select Windows Disk Image Burner or another CD/DVD burning program.
    2b. Put a CD-R or DVD-R into the DVD/CD drive and select Burn. Wait for the burning process to finish.
    3. Restart computer and press F10 or appropriate function key for your computer to enter the temporary boot menu. It may be F12 or F9 etc. Look at the first screen that appears when you turn on the computer and you will see which key to press. You also could enter the BIOS and change the boot order if you would prefer that method. Many computers already have the CD/DVD drive as the first boot drive so you may not have to do this step.
    4. Select CD/DVD from the boot menu.
    5. The Ophcrack LiveCD will now boot. Hit enter to select the Graphic Mode option when it appears.
    6. Ophcrack will automatically begin cracking your passwords. The longer and more complicated the password is the longer it will take to crack. 99% of passwords are crackable. Any password over 14 characters cannot be cracked. This program found my 8 character password which contains letters and numbers in less than 10 minutes.
    7. Write down your password when it's cracked. Remove the CD/DVD and restart computer.
    Feb 19, 2011 | Sylvania G-Netbook
    Administrator mode
    Hello!
    OK ..Click start and then "log off" when computer prompted you to type username;
    username: administrator
    Password: ___________, leave in blank
    but if the computer just only need the password on the user, you should simultaneously Press " Ctrl+ALt+ DElete" do this successive two times( 2x)
    prompted you like this; then type,
    and then enter..
    any problem arising this solution please tell me.
    best regards, melnavz
    Feb 21, 2008 | Acer Aspire™ T180 PC Desktop
    Dell Inspiron 530 -Intel® Pentium® dual-core processor E2180 , Genuine Windows Vista® ... PC Desktop Logo
    60 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
