Question about HP Computers & Internet
I think my motherboard is bad. My computer won't turn on. Have tested the power supply and I believe it is good. When power cord is plugged in the green light is on but very dim. When I disconnected the power supply to the motherboard the light gets bright. Do you think it is a motherboard?
  • 62 Answers
Despite that the green light is on, your PSU can be defective. You can follow the instructions found here to test your PSU. You can also use a use paper clip instead of wire. If your PSU starts when it's not connected to your mainboard you can make a second test, if you don't have a voltage meter, to see if voltages are OK. You could connect your optical drive to the PSU and see if your drive unit door is opening and it reads discs (without data cable connected). If your PSU will start (cooler rotation is OK, optical unit will work), then your PSU is probably OK. Next step would be to reset your CMOS settings, if PC will still not start then I would say your mainboard is defective. And, of course, proceed at your own risk.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Posted on Sep 07, 2010
  • HP Master
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
  • Brian Sullivan
    Brian Sullivan Sep 07, 2010
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
    good luck
My Gateway DX 4300-05 won't start. Not even the power supply. Does the motherboard have a reset?
If I am reading the frist part of your stament correctly, the power supply does not even kick on when you press the power button. Don not unplug anything from the inside of the computer at this time, instead check your power cord and make sure it is plugged in thightly to both the computer and power strip. Check to make sure the power strip is on, plug something else (like a light) and test the power strip. If the item does not come on, then you may have a bad power strip. To confirm plug the item you are testing with into the outlet the power strip is plugged in to and see if it works. If not your outlet may be bad, contact an electrician. If everything works, but the power supply is still not kicking on, you possibly have a bad power supply. You will need to pick up a replacement power supply and install it in the computer. This is were you unplug everything wire bundle that comes from the power supply to the mother board (paying attention to what was plugged in where). Take the new power supply, install it, plug everything back in. Now try the power button. If this fails then yes you have a bad mother board.
I know most computer retailers that offer repairs, have a device to check the power supply. A good repair place will check this at little or no cost to you, if you agree to let them install the replacement if it is bad (they will charge you for the power supply and installation of it).
I hope this helps
Jun 12, 2012 | Gateway Computers & Internet
The computer acer x3200 goes dead and wont come back on unless the power cord is removed for a few seconds when it goes dead it is as though the plug is out
Your power supply is going bad or there is a bad start-up capacitor on the motherboard that's bad. Replace the power supply or have it tested from a qualified technician. If the power supply is good, then the motherboard has a bad capacitor.
Dec 29, 2010 | Acer Aspire X3200 PC Desktop
Can't power up. Fluttering green light on front below on /off switch, and on the back of the power supply. AC input is good, and I tried a different power cord and AC outlet. Fans do not spin when I try...
If you can open up your PC, disconnect the power supply to motherboard plug and try power on again. If still the same replace the power supply. Draw a diagram of connections from the power supply to the mother board.
Jan 05, 2018 | Compaq Presario SR1111NX (PC146A) PC...
Dell Dimension 5100c Model: DCCY will not boot.
Is the power button a steady abmber light?
If so follow the instruction below>>>>
Remove the power cord from the back of the computer. Then open the side casing of the tower and unplug the 24 pin block connector from the motherboard. The 24 pin block connector looks like this >>>>>
Once removed press the on/off button on the computer to dispel and residual power from the motherboard.
Then connect the block connector again and put the side panel back on and then plug the power cord back in and try to boot the computer up.
If its still the same then the power supply inside the computer may need replacing.
Good luck.
Jul 03, 2010 | Dell Computers & Internet
Computer wont turn on after power surge
You can try to change the sockets to which it was connected, try to plug the power cord of PC to different socket on surge protector or try connecting it directly to wall jack..
Jun 19, 2010 | HP Pavilion a1440n PC Desktop
HP a1050y....Push the button to turn it on, and
You might have a bad power supply, or something might have loosened inside the case. sometimes if the memory or processor get jarred , they might need to be reseated. unplug all the cables from the back of the tower, only leave the power cord in then try to power up. Sounds like it might be power supply or Maybee the motherboard. Have a computer tech check all the inside connections. Good luck..
Mar 31, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
NEW BIOSTAR MOTHERBOARD DOES NOT BOOT
Good day sir, let try to test first the power supply, Unplug the power cord, remove the 20 pin (24 pin for the late model) molex power connector from the motherboard, plug in the power cord, get a 2 to 4 inch jumper wire, short the green wire with any of the red or black wire on the molex 20 pin power plug, the result maybe the following:
  1. you will see the power supply fan turn. you power supply is in good order. replug the power supply, and test again.
  2. you will see the fan turn for a few second then stops. you power supply is selective, and may require a different type of motherboard. Get a new one.
  3. you wont see the fan turn at all. get a new one.
If in case you are with #1. uinplug the power cord and remove all the expansion cards, data cables from the hard disk and cd drives. we are trying to isolate the problem. make sure that the only connected cables on the motherboard are as follows:
  1. 20 pin power cable.
  2. 4 pin 12 volt power cable (if applicable)
  3. speaker
  4. power switch
  5. power led
Test the pc once more. plug in the PC. If still the board wont power on. problem with your motherboard. Note:make sure your RAM is good. Hope this helps.
Aug 26, 2009 | Biostar I865GV-M4 (MB865GVM4) Motherboard
Ps3 no power no lights cord is fine switch is fine HELP!!!!
Its possible that the power supply isn't putting out all the voltages required for the ps3 to turn on. Best way to verify it is if you had another known good working power supply to swap it with. If you can swap the power supply and get the ps3 to turn on then you know your power supply is bad. If it still gives you the same problem after swapping then the main board is bad. I believe the ground should show 5 volts. if the 5 volts isn't present then the power supply is definitely bad.
May 06, 2009 | Sony Playstation 3 (PS3) Console
Fast green blink
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
1.Disconnect everything from the computer, including the power cord.
2.With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
Performing this step ensures that the voltage switch is engaged and set correctly for your country/region.
4. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
5. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
6. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
8. Remove all attached devices except for keyboard, mouse, and monitor.
9. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
10. Check the power switch:
a. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
  • If the button sticks, it should be replaced or serviced.
  • If the power button does not stick and appears to be functioning, continue using these steps.
11. With the power cord disconnected, remove the case or side panel.
  • Follow the wires from the power button on the front of the computer to their connection on the motherboard.
  • Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard.
  • Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
12. Find the defective part:
  • With the power cord disconnected, remove the case or side panel.
  • Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference.
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
13. If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
14. If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
15. If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
NOTE: If an electrical storm or power surge has recently occurred, then it is more likely that the power supply, the modem, or motherboard is damaged and requires replacement.
Apr 11, 2009 | HP Pavilion a340n (DQ099AABA) PC Desktop
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
